Kswap into Eg, fuel line help
My shell I bought had the hardlines cut by the steering knuckle.
I bought the hybrid racing tuck kit but it has no fittings to attach to any of the hard lines.
They are 6an fittings but how do I attach to the feed to the regulator.
Pics of yours please?
Re: Kswap into Eg, fuel line help
The quick and easy way is to remove the 6an fittings from the kit that would go to the feed and return, slide the hose end over the hard lines and clamp them. The other options are to find the 5/16th 6an flare fitting for the feed and the (I believe but verify) the 1/4 to 6an flare fitting for the return, install the fittings and flare the lines OR the last option is to remove or bypass the steel lines and run 6an to the tank with a 90 degree 6an bung on the tank lid and reuse the existing feed on the tank lid for the new return line.
Pipe cutter and these vibrant fittings, no need to flare with them. That's what I did, 1/4=.250 return and 5/16= .3125 is the feed first 2 products on the page. https://vibrantperformance.com/catal...ea216bae9e8ebd
B_Swapped93
04-04-2019 10:02 PM
95accordian
07-19-2016 08:35 AM
89sicivic
01-31-2006 08:19 PM
