Use a 06 civic si ecu and harness for eg hatch swap????
Old 03-15-2018, 09:06 PM
hondaman177's Avatar
Default Use a 06 civic si ecu and harness for eg hatch swap????
Can i use stock engine harness and ecu for my swap i have a full running donor car fully built k 20z3 made 300 all motor my hatch is gutted to a bare shell nothing dedicated drag car no oem cluster nothing. I’ll use a laptop for that stuff and data log
Old 03-15-2018, 09:16 PM
JRCivic1's Avatar
Default Re: Use a 06 civic si ecu and harness for eg hatch swap????
Anything can be done... but that will be a hard wiring road. There are MUCH easier ways to make your car run than what you have asked.
Old 03-17-2018, 06:02 AM
Well i have my 06 si fully built k20z3 and trans in swapping to my hatch. But it’s a drive by wire set up. Has anyone done this using the harness from my 06 or is there a stand alone engine harness i can get? This is a dedicated drag car never done a k swap but once in a Integra so i don’t need my factory gauges etc to work. Just need a engine harness and a ignition switch
Old 03-17-2018, 01:30 PM
I also have a drive by wire setup
Old 03-20-2018, 04:11 PM
been there done that
doood's Avatar
Use an rsx harness and kpro
Old 03-20-2018, 08:39 PM
JRCivic1's Avatar
I second this... there is no reason to make this hard.
Old 04-01-2018, 05:56 PM
Went cable drive and Chandlerautosports is building my milspec tucked harness said f it not enough help
Old 04-01-2018, 05:57 PM
Also went haltech ! 🤨🤟🏽
Old 04-02-2018, 10:52 AM
Dublocivic's Avatar
3rd this. Old miner's secret - look for gold where gold has already been found.
thekid2390
06-18-2013 11:36 AM
D_koschak
01-21-2011 05:46 PM
eg6sittingon57cs
10-01-2009 08:50 AM
McLovin
04-25-2008 09:57 AM
SHG_Mike
06-13-2007 06:40 PM
Quick Reply: Use a 06 civic si ecu and harness for eg hatch swap????
