Honda Insight ECU Pinout
Dear All,
This is my peggyback detail and i want this peggyback install with Honda Insight K-Series ECU, Engine code is LDA3. Kindly requested you to provide me ECU pint out for this peggyback.
Signal Name Type Explanations and Remarks
LOAD2 Sensor Sensor In LOAD No.2 from Sensor
LOAD1 ECU ECU LOAD No. 1 To ECU
LOAD1 Sensor Sensor In LOAD No. 1 from Sensor
IGT4 Coil COIL No. 4 Coil Trigger
IGT4 ECU ECU No. 4 IGT Signal from ECU
IGT3 Coil COIL No. 3 Coil Trigger
IGT3 ECU ECU No. 3 IGT Signal from ECU
IGT2 Coil COIL No. 2 Coil Trigger
IGT2 ECU ECU No. 2 IGT Signal from ECU
IGT1 Coil COIL No. 1 Coil Trigger
IGT1 ECU ECU No. 1 IGT Signal from ECU
GND PWR Power Supply Ground (E1)
TPS Sensor TPS (VTA1)
+12 V PWR +12V IG-on Power Supply
SPD(4P) or Ext. Sw Sensor Speed Sensor Ext. SW. #1 - #2
