Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
Need info in k-swap HONDA FIT 2003
what engine mount kit ,stock subframe will work or not ..........
Re: Need info in K-swap Honda FIT 2003,,,engine mount kit ,subframe.....
if you put the k24, you might need to get a mount that sits a bit lower....and your gauges.... none of them will work... there are a few parts list, but for the fit everything seems pretty *** to find someone who has done everything correctly and have it work.
what about for the k20z3? will the mounts work?
OEM mounts will not work as is. Contact Hybrid Racing if you're serious about this and ready to put the cash down. Expect to spend a minimum of $5K, not counting the engine and trans.
LeonardDB
04-18-2011 08:41 AM
Con
23
12-18-2010 03:34 PM
0554
10
03-05-2003 10:29 PM
