Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission problem
Old Sep 8, 2014 | 11:26 AM
87integra's Avatar
Default Transmission problem
Should I use oil or Honda Transmission fluid. Why is because it's Grinding on third gear. I ask some people an they say to use Honda Transmission fluid because the Transmission has LSD on it.
So which one should I use Honda fluid or oil?
Old Sep 8, 2014 | 12:13 PM
holmesnmanny's Avatar
Honda manual transmission fluid is the best, hands down
Old Sep 8, 2014 | 12:47 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Transmission problem
Use the fluid the LSD maker recommends.
Old Honda MTF (1st gen) was great. The pisswater they sell now sucks for older transmissions. For 87 Teg 10w30 is perfect.
Old Sep 9, 2014 | 05:29 AM
87integra's Avatar
Will its a 92 cable LSD transmissions. So I will have to go Honda fluid
Old Sep 9, 2014 | 07:30 AM
Mista Bone's Avatar
D Tranny Guru
10w30 will be fine.
Old Sep 10, 2014 | 11:06 AM
Aquafina's Avatar
What LSD is in it?
Fluid will not fix a grind, only cover it up making you think it is fixed but hurting your wallet more in the long run. Do not run Honda MTF. 10w-30 is much better to use.
Old Sep 10, 2014 | 10:48 PM
slowcivic2k's Avatar
A defective gear shift is caused by driver error, defective linkage, or defective parts within the transmission. No fluid will cure this, only mask it. Pull it out, and inspect it.
Old Sep 11, 2014 | 12:36 AM
mike_1212's Avatar
I agree. Is it just 3rd gear? If so, your probably gonna need to rebuild or replace... changing the oil isnt going to fix it.. just prolong the inevitable... (failure) look into a used trans. And swap it.
Old Sep 11, 2014 | 07:49 PM
87integra's Avatar
It only Grind on third gear when you race that all it drive normal
Old Sep 12, 2014 | 06:37 AM
MR.johnson's Avatar
That statement is 100% wrong.
vlc92189
41
Aug 16, 2013 11:19 AM
SIRIUS
Jun 5, 2011 12:23 PM
jonaldjenkins
Mar 14, 2008 07:39 AM
Wes V
Nov 2, 2003 12:02 PM
Buckshot
Apr 5, 2003 11:20 AM
