GSR / ITR mainshaft 5th gear compatibility
1 Post
Both the GSR and the ITR have a 33 tooth 5th gear on the mainshaft, yet they show different part numbers.
Are the gears different (diameter? gear tooth pitch?) even though they have the same tooth count?
1 Post
Re: GSR / ITR mainshaft 5th gear compatibility
Confirmed from a friend of mine that knows way more about them than I do:
"Diameter on each MS gear is different. Side by side you can tell by just looking at them there is a difference in size. It will also be obvious during assembly if there is binding or if the gear is too short to engage the sister gear correctly."
