Cable B-Series transmission bearing
Well, I was trying to test fit my cases together after rebuilding my cable B16 trans, and the top mainshaft bearing got stuck in the upper case half. As I tried to get it out, it busted open, sending ball bearings everywhere....
Im having trouble finding this bearing alone, and for a decent price. The part number is 91004-PS1-003. Measurements are: 70mm OD, 22mm ID, 18mm thick. Most places have it listed as discontinued, but the the places that dont have it listed at around $60... Found it on ebay too, same price...
Does anyone know where I could get this bearing for cheaper? Or does anyone have a good used one lying around? Im pretty sure its the same bearing as the LS cable transmissions.
Thanks!
Thanks!
D Tranny Guru
Re: Cable B-Series transmission bearing
Why not reassemble the bearing after cleaning, then check mainshaft shimming?
Check with Dave or James at Synchrotech, forum sponsors here for a reason.
Next time use a space heater and the bearing will drop out with ease.
Ive been trying to reassemble but can't get it back together... any tips?
Already talking with synchrotech
And it was a bit of surface corrosion that got it stuck. Just took some 400 grit to the bearing bore and its all clean now, and three outer race slides in beautifully.
I don't know, I can't see any way to get it back together... how do you hold all the ***** and the cage? Do you insert it at a certain angle? I just don't see it.
Any tips on reassembling this thing? Im just not seeing how this thing "just snaps back together"...
D Tranny Guru
Right, races like that are pretty straight forward. Hell, they hold the damn ***** for you lol. No matter how much grease I use, or magnets, or tape, etc I use, I cant get the ***** to stay around the inner race... Maybe ill try hot glue, then melt it out after...
But thanks for the pics, it at least lets me know the theory.
Wopsicle69
01-06-2005 04:44 PM
