Transmission & Drivetrain Gearboxes, Differentials, Clutches
good or bad
Old Mar 11, 2009 | 10:51 AM
avotegra's Avatar
Default good or bad
i found a usdm 98type r transmission with 190000 mile....guy wants 600 for it....say it shift good...but when i went a check out the transmission...by hand turning the input shaft. you can hear a clicking noise or a low sparking noise....is that normal for a lsd type r transmission...............
Old Mar 11, 2009 | 01:26 PM
avotegra's Avatar
Default Re: good or bad
is it worth the 600 for a type r tranny with that many miles
Old Mar 11, 2009 | 05:26 PM
Mindgamez's Avatar
The LSD alone is worth 400 and if it has 4.7 Yea its worth it. But the clicking noise is most likley a stripped gear or Stripped Main/Counter Shaft teeth. When you turn it by hand is the Mainshaft really stirdy or moves around in a circle? If so new Bearings too. Most Likley its worth like 300-400 and is need of a Rebuild
Old Mar 12, 2009 | 12:12 AM
avotegra's Avatar
i guess its not worth it then.....ill offer him 300 see if he'll want it
Jimmy
May 28, 2011 12:53 PM
mmsj1
Jun 26, 2010 05:12 PM
xseekanddestroyx
Aug 22, 2007 07:37 PM
Awojtecz
Nov 20, 2004 05:11 PM
