Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help please
Old Mar 17, 2009 | 11:05 PM
aarsen43's Avatar
Default Help please
1990 honda civic, manual.
problem
when i pull up the clutch when it is in neutral it makes a pff sound
could this be a problem with the release bearing, or a bearing or seal in the transmission
any advice would be great
thanks
Old Mar 17, 2009 | 11:30 PM
jaycivicex's Avatar
Default Re: Help please
you need a new throw out bearing. Its the one inside the tranny connected to the fork
Old Mar 17, 2009 | 11:32 PM
aarsen43's Avatar
that's what i thought, thanks a lot for the advice
Old Mar 17, 2009 | 11:40 PM
jaycivicex's Avatar
no problem. If you buy a new clutch kit it should come with both bearings.
Old Mar 18, 2009 | 12:47 AM
Mista Bone's Avatar
D Tranny Guru
more info is needed.
I doubt the throwout bearing is at issue, I've only seen ONE bad Honda TOB in 10 years, but close to a hundred bad input shaft bearings.
Jazlynsciviclx
11
May 30, 2014 07:43 PM
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
KHaoTiK
12
Feb 23, 2010 02:29 PM
eda6
Jan 26, 2008 03:26 PM
aznrexboi00
21
Oct 1, 2005 09:02 AM
