Transmission & Drivetrain Gearboxes, Differentials, Clutches
No Reverse
Old Mar 15, 2009 | 12:45 AM
bboysake's Avatar
Default No Reverse
So recently my reverse just went out. I try to put it into reverse but it doesn't seem to go into gear. I can get it half way into it, and occassionally when I try multiple times it goes into reverse, when I do get it into reverse it makes a weird clanking sound inside the tranny or around the transmission area. The reverse light doesn't come in either. What could've went out?
Old Mar 15, 2009 | 04:45 AM
Honda Bull's Avatar
Default Re: No Reverse
The reverse pieces. The 1/2 shift sleeve. Won't know until you pull it apart. Nothing more any of us can really help you with unfortunately. Just gotta do it.
Old Mar 15, 2009 | 09:08 AM
bboysake's Avatar
So I need to pull apart my motor first? What exactly will I be looking for? Im not too sure of myself on the transmissions. I havent really worked with transmissions yet
Old Mar 15, 2009 | 01:50 PM
Honda Bull's Avatar
Don't need to pull the motor apart; just need to remove the transmission from the motor, then crack the transmission casings open.
Before you try that, have a look at the B-Series Trans tutorial I made in this section of the forum. It'll be on page 1 or 2. But it is definitely in the FAQ/Links. Read over that and see if you'll be comfortable working with one. If not, give the transmission to someone else so they can help you out.
Old Mar 16, 2009 | 09:24 PM
bboysake's Avatar
Thanks Bull, I appreciate it a lot. I'll definitely take a look at it. So once I crack open the case what should I be looking for? anything in general? I'm pretty new to transmissions.
magicm
Dec 3, 2012 06:25 PM
Eg8Don
Welding / Fabrication
Aug 17, 2010 07:11 AM
rleonekc
Apr 6, 2006 06:05 PM
kihun_cha
Dec 19, 2005 02:34 PM
ELAMINT5
Jul 30, 2004 07:33 AM
