Transmission & Drivetrain Gearboxes, Differentials, Clutches
hard to shift
Old Mar 24, 2009 | 10:43 AM
H2BSTUPID's Avatar
Default hard to shift
Hi, my buddy just installed a b18b swap in his 93 civic.. everything runs fine but... whe found it hard to install the shift linkage it almost felt like it was too long. Then we take it out to drive and the shifter is really stiff and you have to muscle it to get into gear. The clutch is good and no grinds or noises in the tranny. Now would it be possible that the linkage is seized??
Old Mar 24, 2009 | 10:48 AM
mn99si's Avatar
Default Re: hard to shift
maybe bushings in the linkage...unless they were already installed also check the double-ended bolt that hold the shifter in place? just suggestions
Old Mar 24, 2009 | 11:07 AM
shietzitzkien's Avatar
i had a similar problem with my integra, turned out i need new syncros.
rwlangdale
Feb 12, 2008 11:15 AM
baastard
May 10, 2006 06:19 AM
BDogggUT34
38
Apr 11, 2005 02:19 PM
crxman00
12
Apr 5, 2003 09:26 AM
CM-R
Mar 26, 2003 10:02 PM
