Transmission & Drivetrain Gearboxes, Differentials, Clutches
B series Trans issues :(
Old Mar 19, 2009 | 08:23 PM
MD-Type-R's Avatar
Default B series Trans issues :(
Hey,
I have a 98 jdm type r motor and trans. I am just finding time to get around to working on my car again after a failed clutch/fw install.
Originally my clutch went out when I was driving. In order to get home I forced it into first gear. I have since replaced my clutch and flywheel and slave cylinder with competition clutch products.
After reinstalling the transmission and bleeding the clutch I can not get into any gear. The shifter sits far forward ( and i have checked to make sure that it is not backwards) and even if i manage to get into a "top" gear such as 1,3,5 it seems very sloppy. I can not tell if it is in gear or in neutral. Also if I put it in a "bottom" gear it sits like it should be in neutral. I have tried 3 sets of linkage, oem, avid, and oem all with the same results.
Its driving me nuts and I really would appreciate some help. Any thoughts?
Old Mar 19, 2009 | 10:42 PM
Aquafina's Avatar
Default Re: B series Trans issues :(
Pull trans.
Split case.
Inspect shifter assembly and shift forks.
Replace as needed.
Old Mar 23, 2009 | 01:09 PM
deeraw904's Avatar
i have the same problem with the top gears on my gsr as well.im clueless on any repairs,but as soon as i find something out i will let you know...
GR_DC2
Jan 23, 2012 09:07 PM
MD-Type-R
Mar 19, 2009 11:17 PM
taimysho0
Sep 24, 2007 05:15 PM
RTW DC2R
Jul 25, 2007 07:30 AM
JDM Like Whoa
Dec 11, 2006 02:30 PM
