Transmission & Drivetrain Gearboxes, Differentials, Clutches
Vibration On Acceleration
Old Mar 20, 2009 | 02:21 AM
92civiceg9gsr's Avatar
Default Vibration On Acceleration
Hey HT my 92 integra is eating up inner cv's causing it to vibrate under acceleration. The axles aren't oem they're advance auto parts lifetime replacements. So about every 6000miles I have to change the axles. The car was slammed on Koni/GC but now its raised up to about 2.5in drop. I've also replaced the radius rod and front lca bushings with ES polyurethane to help with suspension flex under acceleration. The motor mounts are oem but in good condition. Im thinking the axle angles are way off or the axles are to short. I've seen so many slammed DA's that I dont know if its the drop. Just throw some ideas my way that you think may cause this issue or things that may help to solve it. Thanks!
Old Mar 23, 2009 | 07:52 AM
aaronfelipe's Avatar
Default Re: Vibration On Acceleration
Vibration under acceleration indicates that your driver side axle needs to be replaced. Vibration at higher speeds ( knowing your wheels are balanced, of course ) is probably because the passenger axle is off balance. I just replaced both of my axles for this same reason. It was driving me insane. ReManned axles have been known for being faulty out of the box.
brians356
24
Oct 16, 2015 12:55 AM
devious
Mar 29, 2010 12:40 PM
92civiceg9gsr
Mar 5, 2009 09:36 PM
Teglessb18
Suspension & Brakes
Apr 4, 2006 12:58 PM
John
May 13, 2002 10:56 AM
