second gear whine
second gear whine
ITR tranny second gear has a slight whine, no other forward gears do it. it dont seem to do it when decelerating in second only when accelerating. recently switched my trans fluid to GM SM friction modified, i was told that second will whine on a ITR tranny due to the final drive , but i thought all the rest of the gears should whine equal why would second be louder?
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: second gear whine
yep, 98 i think went to ball bearings. not sure if and when the H series picked up ball bearings...maybe someone knows for sure.
The GSRs and ITRs switched to the closed ball bearings somewhere around 96-98.
Never pulled an H-Series apart yet.
D Tranny Guru
when in second gear, the roller bearing under the countershaft second gear would not be moving, therefore cannot WHINE.
Two things.
Either due to the gear pitch the whine is normal, or first or third roller bearing is at issue.
Two things.
1 Post
ok that makes sense since that the 2nd gear engaged is spinning at same rate of countershaft speed since it's locked via the hub/sleeve. if it's not the pitch noise, that would leave not just 1st and 3rd needle bearings to question, but 4th and 5th as well...no?
ok well im getting whine in all forward gears now , all be it very faint, i cant help but wonder if i need a thicker fluid. the GM syncromesh fm i am running shifts like a dream but the whine started shortly after switching to it.
vdawg559
12
06-09-2008 06:21 AM
