Transmission & Drivetrain Gearboxes, Differentials, Clutches
Problems after trans work
Old Mar 19, 2013 | 04:48 AM
Smashback's Avatar
Default Problems after trans work
Story of my life it seems like somtimes...
So this is my first time working on this trans. Didn't seem too bad, but I'm a bit worried after a short test drive. There's a whining during acceleration, and a grinding type sound upon deceleration while in gear. It also acts a bit funny about reverse, sometimes not wanting to go in or out of reverse until it I let it roll just a bit.
Car is a pretty much stock (for now, this is prep for turbo install coming next) 2003 Type-S, all was fine before.
What I did:
MFactory Helical LSD
Gear-X 4.05 Final Drive
M-TEC Street Shift Springs
Clutchmasters Lightweight Steel Flywheel
Clutchmasters FX350 Clutch, PP and throwout bearing
Pennzoil Synchromesh
Am I going to have to tear this thing apart again?
I posted that on k20a org a few days ago with not much response so I'm trying here now. Someone posted a link to measuring mainshaft endplay but I don't think that applies since the main was untouched.
I *thought* I correctly measured the diff shim clearance at .003 but I might have done it wrong. My question is, can I measure that with the trans in the car if I pop out the axles and use a pipe or similar to seat the diff (as shown in Helms)?
Assuming this shim is the problem, I'm assuming the one in there is too thick according to what the trans is doing...or no? Any and all help is appreciated.
Old Mar 19, 2013 | 01:09 PM
Smashback's Avatar
Default Re: Problems after trans work
Nobody at all?
Old Mar 19, 2013 | 07:10 PM
Runnerdown's Avatar
I don't believe this issue can stem from the shim being off a little bit. I have taken some apart with way too tight of a shim and it just shortened the life of the diff bearings. The whining sounds like it could be caused by an issue with gear mesh. I'd say it needs to come apart for a thorough inspection.
Old Mar 19, 2013 | 07:25 PM
Smashback's Avatar
Actually that's what it reminds me of, like when a rear end diff isn't set up right, but unless the final drive set was bad, which seems hard to believe, I'm not sure what else it could be. Seems like something may be a little loose...that slight grinding/clattering sound..
yungmulacrx
17
Jan 8, 2014 03:47 AM
SoHc94
Aug 15, 2011 09:52 PM
B00stedEh3
Apr 18, 2011 12:45 PM
MattNYC
Jan 8, 2011 05:55 AM
nospeedlimit143
Aug 26, 2003 05:03 PM
