Transmission & Drivetrain Gearboxes, Differentials, Clutches
Fins broken inside case
Old Apr 29, 2013 | 07:46 AM
josephcmiller2's Avatar
Default Fins broken inside case
This is an S80 hydro GSR transmission. Some of the fins in the bottom of the case near the diff are broken. I'm assuming they are there to direct oil flow to the diff. Will this be a problem?
Old Apr 29, 2013 | 03:27 PM
94EG8's Avatar
Seagull Management
Default Re: Fins broken inside case
They add some strength as well. Should be fine though, you have to grind them down a bit when installing an LSD.
Old May 5, 2013 | 06:11 PM
f20b jones's Avatar
What he said. They will be fine. I have to take them almost completely out when putting a stock h series lsd in a non lsd casing.
civicomax
26
May 10, 2021 03:30 AM
93lsd
Apr 11, 2004 06:21 PM
mafay2
Sep 4, 2003 05:36 PM
Victor Penner
Jul 10, 2001 04:38 PM
