Transmission & Drivetrain Gearboxes, Differentials, Clutches
Shorter-ish geared D series trans question
Old 03-07-2013, 02:56 PM
stallinrawlings's Avatar
Icon2 Shorter-ish geared D series trans question
i have a 96 ex coupe. (s40 trans)
i have an s20 sitting in my basement waiting to be put in my car.
before i do that however i am curious to see if i can do the following:
take the 4th gear and final drive out of a 7th gen (2002 EX)
the gear ratios are:
mine:
3.250 1st
1.909 2nd
1.250 3rd
0.909 4th
0.702 5th
4.250 final drive
the 2002 ex:
3.143 1st
1.870 2nd
1.241 3rd
0.970 4th
0.757 5th
4.412 final drive
1st - 3rd i don't want - but 4th, 5th, and the final drive are shorter.
i'm not looking for a huge difference here - my car is a daily.
however i want it to be just a little quicker.
so the question is:
can i swap these gears? will they fit?
Old 03-07-2013, 03:28 PM
Seagull Management
94EG8's Avatar
Default Re: Shorter-ish geared D series trans question
Honestly, I don't know. I want to say no. I will say though that if you can find a '92 - '95 CX/VX trans you can use 3rd gear from that as a short 4th in an Si trans.
Old 03-07-2013, 03:32 PM
that's interesting... i didn't think you could do that. (swap gears to other gear slots i mean)
Old 03-07-2013, 03:34 PM
are there other gears that i can do that with? cause i haven't started this yet, so i'm doing my homework haha
Old 03-07-2013, 03:40 PM
Seagull Management
94EG8's Avatar
It's just 3rd and 4th you can do it with. The reason being they share a common sleeve and hub, and both halves of the gearset can be removed from the shafts. Besides the ratio 3rd and 4th are identical in their demensions. You could do the same thing with 1st and 2nd if the mainshaft gears weren't cast as part of the mainshaft itself. Not that it would really help you any, All '88 - '00 D-series transmissions use the same 1st gear so it's not like there was a long 1st gear you could use as short 2nd.
Old 03-07-2013, 03:46 PM
MR.johnson's Avatar
yeah. I just built a single stick trans with mfactory diff and vx 3rd for fourth
Old 03-07-2013, 05:40 PM
so now my question is this:
what's the best/easiest way that i would acquire such a fine piece of hardware. (O.o)
lol
Old 03-07-2013, 05:41 PM
cause if possible i'd rather not buy a whole other transmission...
Old 03-07-2013, 06:33 PM
Seagull Management
94EG8's Avatar
lol
You can see if Synchro-tech or Gearspeed have any new or good used gears or you can buy a used transmission (usually the cheapest option as long as you get one with a good 3rd gear)
The third gearset is discontinued from Honda so you can't just go to your local dealership and order it anymore like you used to be able to.
Old 03-08-2013, 03:57 AM
sucks about the dealership - but that's how it is for a lot of stuff now with 90's honda...
i'll check, thanks so much man, time to get to work.
TOM KREUTZBERG
02-13-2014 04:04 PM
jasonp
02-25-2009 08:12 PM
oneludesol
01-27-2008 08:37 PM
FLATOUTRACING
33
04-18-2004 11:50 AM
FastechAccord
03-24-2002 04:15 PM
Quick Reply: Shorter-ish geared D series trans question
