Transmission & Drivetrain Gearboxes, Differentials, Clutches
oil seal on diff.
Old Feb 27, 2013 | 04:33 PM
james d's Avatar
Icon2 oil seal on diff.
change my diff. oil seal because it was leaking.. i replaced it with new seals still leaking... need help guys
Old Feb 27, 2013 | 08:17 PM
Aquafina's Avatar
Default Re: oil seal on diff.
What transmission and what were the seal part numbers used? How did you install the new seals? How do the axles look?
Old Apr 11, 2013 | 08:50 AM
james d's Avatar
its on a acura integra rs... i bought the car ang the guy told me the axles are new... so i said ok so its the oil seal... when i bougth the oil seal i tried fitting it on the axle before putting it in and the seal was fine.. when i test test drove it it still leaks maybe its the inner cv joint? if the axle are in the spline and locked if u move it up and down is it normal?
Old Apr 30, 2013 | 02:39 PM
slowcivic2k's Avatar
Get a Honda oil seal, seriously, get a Honda seal. I've seen this too many times and its always been the seal. But check the seal surface on the axle for damage while its out.
Old May 1, 2013 | 07:21 PM
MR.johnson's Avatar
any play in the axle when its popped in?
OOOtony
Apr 22, 2009 10:50 PM
8083tcman
Dec 30, 2008 08:43 PM
hammergunner
Sep 6, 2008 10:39 PM
EFresh
Jul 31, 2006 01:44 PM
serious
Apr 8, 2003 03:47 AM
