Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission Problems
Old Mar 13, 2013 | 10:10 AM
alexcoreas10's Avatar
Default Transmission Problems
I have a 05 type s and I was wondering if its a transmission issue I have. Everytime its in any gear and while driving there's a knocking sound and when I go faster the noise speeds up. I changed both cv axles already and still same problem. What's better to buy a LSD transmission or rebuild the stock one and add LSD? Thanks.
Old Mar 13, 2013 | 10:35 AM
David @ Synchrotech's Avatar
Default Re: Transmission Problems
It could just be a rock stuck in your tire, but it's probably a broken tooth on the ring gear. You should open the trans to inspect everything and add a LSD while you are having it repaired.
playlife
Jun 3, 2011 12:12 PM
littlerichie34
Feb 27, 2009 01:37 PM
PrecisionH23a
Apr 29, 2006 09:29 AM
chambersef8
Apr 1, 2004 06:03 PM
EF_LSVtec
16
Sep 18, 2002 10:59 AM
