back purge?
Old Feb 26, 2006 | 11:51 AM
PTR1's Avatar
Default back purge?
i was wondering how do you guys back purge? welding up a turbo manifold as an example
Old Feb 26, 2006 | 12:26 PM
david@didrace.com's Avatar
Default Re: back purge? (VIMPORT.COM)
https://honda-tech.com/zerothread?id=1459690
Duct tape.
Old Feb 26, 2006 | 01:36 PM
cua0's Avatar
you always weld in close proximity to your acetone jug?
Old Feb 26, 2006 | 01:53 PM
Default Re: (cua0)
Hell yes, I usually soak my gloves in it and douse it all over my clothes before I weld also.
Old Feb 26, 2006 | 02:16 PM
jon volk's Avatar
Default Re: (backpurge)
aluminum foil is sweet
Old Feb 26, 2006 | 03:26 PM
JG-Fabrications's Avatar
Default Re: (k20 jon)
I built my own purge plugs
Consturcted of High Temp Silicone (rated to 800f) basically they are freeze plugs, that handle great heat, just stick the hose on one side and let air blead out the other, there is a whole drilled in the bolt holding them all together, I could build and sell these for $15 shipped per set (set is 2) I have welded with 120 amps 1" away from these without them even getting soft, they have not caught fire, or moved at all. Here is some pics of them
-James
kevino002
Nov 14, 2006 05:34 AM
NextGear
Jul 5, 2005 11:11 PM
austrian type-R
Apr 15, 2003 08:17 PM
pub
Dec 21, 2002 03:50 PM
B_CRUZ!
Jun 9, 2002 02:32 PM
