Warped Flange... crush gasket?
Old 02-17-2006, 09:08 PM
HamiltonRex's Avatar
Default Warped Flange... crush gasket?
I made my own downpipe.. and when i welded the flange the ears warped upwards a bit.. now it seems the center section is still flat.. and it should seal.
But its a pain to get everything together (parts are all a tight fit.. no space)
Now.. I have a decent belt sander, should i try to smooth it out with that? Or do they make such thing as a crush gasket.. someting a little thicker that will help it seal?
Thanks
Old 02-17-2006, 09:51 PM
B18C1CYA's Avatar
Default Re: Warped Flange... crush gasket? (HamiltonRex)
Belt sand it flat
Old 02-18-2006, 03:50 PM
Default Re: Warped Flange... crush gasket? (B18C1CYA)
thanks!
Old 02-18-2006, 07:44 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">Belt sand it flat </TD></TR></TABLE>
Old 02-18-2006, 08:06 PM
blueoval557's Avatar
Default Re: Warped Flange... crush gasket? (Bailhatch)
Try the belt sander, itl probably do it. If not, try to find some "dead soft aluminum gaskets". They are really thick and super soft to conform to even the worst gaps! GOOD LUCK!
Kyle
Old 02-18-2006, 09:35 PM
RCautoworks's Avatar
Default Re: Warped Flange... crush gasket? (blueoval557)
Exhaust silicone maker works to
Every rsr exhaust I installed the flanges were warped, go figure. Anyways you spready this on like peanut butter and you're good to go.
Old 02-18-2006, 11:36 PM
King-Kong's Avatar
take it down to the local machine shop and get it chopped true, dont half *** something that you dont want to do twice, do it once correctly and thats it. If you have a piston ring machine shop locally they would be able to do it for ya.
Old 04-21-2018, 12:05 PM
JoePublicVA's Avatar
Thanks
Better late than never. Try one of these to keep your flanges flat.
C Flange Bracket.
sirjmj
04-08-2009 06:15 PM
Mike VR6
35
03-02-2007 03:23 AM
ityab0y
Welding / Fabrication
02-15-2005 09:48 AM
Hoosier Daddy
05-10-2004 11:19 PM
mike93eh
13
01-25-2004 12:55 AM
Quick Reply: Warped Flange... crush gasket?
