- Aftermarket Cruise Control
- i want to add a extra l7 in to my ek! any advice on how it can be done?
- CD player keeps starting over
- how do you wire a isolator for two batteries?
- How to program my 99 civic Keyless entry to my 00 civic?
- pdoor speakers
- idatalink...
- Alarm MODIFICATION/UPGRADE question
- 2002 radio wiring diagram
- Opinion on Q-Logic Kick Panels
- Ignition kill switch
- Alarm Recommendation for a Cargo Van
- 99si radio problem
- Screw Amps to Sub Box? Bad?
- Broken wire in left door grommet for my left power window, how to fix?
- Proper enclosure volume
- Speakers Don't work.
- Power from the fuse box and dimmer control to accessory - Right way to do it? 2003 Civic LX
- Opinions on my proposed setup
- equalizer install in 98 civic hatch...static noise!?!?!?
- KENWOOD KDC MP355
- when hooking up your amp where do you guys get that contant 12v power from (REM)
- 2 channel amp or multi channel?
- initial pics from my first install
- Will a poor ground cause a short/ inline power fuse blown
- JL 450/4 4504 Amp Questions
- how many watt speakers to replace stocksbut keeping stock radio
- voltage rating on diodes?
- 6 disc changer and new stereo
- two way or three way 6x9 for rear fill??
- XM antenna location?
- high amp aternator(92 civic si)
- putting 6x9's in eg?
- Radio Died
- Hooking up alarm
- Subwoofer not hitting. AMP may be the problem.
- Kicker 12" L7 and Kicker Zx750.1 AMP
- I need a louder alarm siren.
- Anybody found a good spot to flush-mount tweeters in the front?
- Amplifier
- Great 6.5 Component Speakers?
- rattle from my subs
- python 990 problem
- 515RSiren BackUp Battery. Alarm.
- JL 500/1v2 and JL 10w6v3: Match made in heaven?
- Can I add more OEM horns to my stock horn?
- Viper 5002 Alarm system
- viper 479v page mode?
- Recommendations on new Head Unit for use with MP3 Player
- Anchoring amp to floor question
- help with my radio
- car got hotwired? need some help
- Remote Wire
- lockable hood locks
- I just barely moved here and...
- starter interrupt issue...
- BRILLIANT RED EK COUPE STOLEN.
- Siren goes off when headlights are on
- What would be better to get? Navigation..
- anyone with DYNAMAT or FATMAT or any sound deadner POST PICS OF YOUR TRUNK PLEASE!!
- INstalling s2K DVD Navi in a 98 EK
- 04 05 Civic EX SE please post your aftermarket radio deck.
- 01-05 civic can i hook up a sub to my factory deck?
- Anyone Upgraded Stock The Stock Sub?
- AM/FM antenna signal amplifier
- Tweeter stopped working, Can I fix it?
- Sup peeps... need help
- Will this amp be ok for my Alpine Type-r 2ways?
- Hooked up amp and sub but doesn't work.
- my alarm works perfectly except it doesnt unlock the doors from the pager, i have to use the key. it
- AMP SETTINGS HELP!!!!!!
- wifi security cam's -- any good ones on the market
- 4 channel & 2 channel AMPs
- Coaxial vs Component
- viper alarm questions
- any ideas what this sub's worth??
- 2000 Civic Stereo Wires
- fiberglass question
- Is "Power Usage" and "Watts RMS" is the same thing?
- New....or used power antenna.
- enclosure idea.....for 00 SI
- EK NAVIGATION
- Help me out with my new stereo....
- Looking for the best alarm system, and audio components....
- Stealth install location for G3 Integra SEDAN?
- RSX stealth alarm install?
- 2007 Honda Fit radio removal?
- 12" subs on back baffle board in 93 EG ??
- Extra Harnesses
- stereo removal??
- Viper 5701 responder LE N.O. starter kill
- keeping stock deck???
- Ipod adpater for hondas...
- 98 Civic .:. Keyless Entry .:. I Expletive-d up!!
- Help with ground issue please!
- pioneer speakers 6x9 any good?
- 12" L7 kicker 20h - what amp??
- power hx2 and directed d2400, something wrong?
- how do you make a indash cd/dvd player to work while driving?
- 1992 civic EG
- Any fiberglass fabricators in Orange County/So. Cal area?
- new system need a head unit but dont know what to get
- Speakers cut out when turning.
- New Acura TL audio project. Please help.
- 92 Acura Integra....sound goes in and out!!!
- 92-95 Civic Hatchback Radio Question
- Tough one for the techs: Eclipse AVN6620 and steering wheel control interface
- Unlock switch on Passenger Side door (Black/Red Wire) doesn't work
- Viper 5002 or Python 902
- Diffrence in pioneer d3 and d4
- which headunit to get?
- Building Walkman Noise Sniffer question...
- A woman wins
- What do i need to install 6x9's in a hatch?
- radio problem.
- viper 5002 pager and glass break sensor question?
- call me stupid if ya got to
- Have alarm but suddenly wont let me communicate with car.
- Alarm Ext. harness?-Concealing under dash wiring? attn:sti killer/suspended hatch
- DIY: Poor mans GPS tracking for stolen vehicle recovery.
- CompuStar CM3300 2-way Xtra Scanner Light Install
- [HOW-TO] TAKE OUT FACTORY DECK FROM ACURA RSX
- 1999 Accord/Viper 5900 R/S Problem
- 97 Prelude OEM headunit P&P in a 97 Civic?
- Good combonation?
- connect 2 amps?
- Alarm problem
- Newb needs assurance on parts -- let the lynching begin
- Clifford self powered siren 515c on a non clifford alarm brain
- Electrical connectors: why non-insulated?
- CBS Evening News – Stolen GPS units
- Wiring deck with short wires
- I got new cd player now sub wont bump..... Help me please.
- Sub enclosure wiring help (Ohms)
- 791xv pager problem
- How to install a line output converter
- Amp (Stereo/Sub) Installation, power wire through firewall, where?
- 6x9 woofers?
- Pioneer DEH-P8000R deck question?
- Suggestions for a 8" sub?
- Thought you guys might like this stellar alarm install
- 97 DX HB needs Aux input to factory
- sub and amplifier
- need help wit sytem install
- just got some new subs, whats some good bumps???
- onlinecarstereo.com? yay or nay?
- Help, question on Alpine DA X300 headunit....
- passport x50 false laser
- Best ground for an amp
- starter wire help
- Have an alarm, any way to get a new fob?
- Low pass filter
- Bright idea while drinking beer!!!
- 97 honda civic hatchback speaker sizes
- viper 5002 questions
- Kenwood DVD Player...
- Security System for a 99 CX
- Looking for quality audio setup suggestions
- Resetting Viper 5900
- garage door motion sensor w/ remote!?
- Bridging my Pioneer GM-X564 ?
- problem with amp.....help please!!!!!
- Fried head unit?
- Security for my trunk housed sub and amp.
- 530t on a 2008 civic???
- 500ESP Arming and zone Bypassing.
- Battery PROBLEM! Alarm keeps going off. 98 Accord
- DEI door trigger wire
- 98 Civic . Stereo Install...Keyless Entry Problem
- Few questions..
- Stereo System Setup
- Is the impact sensitivity set too high?
- Funny thing with the stero.
- Lights don't flash when i arm car
- How to wire Speakers for 4 Ohms?
- non honda...sub placement for trunk enclosure
- looking for an in-dash navigation/dvd unit
- 01-05 Civic Double DIN deck install
- Compustar install problems
- Subs Not working right AMP wire help
- are there rca jacks in my oem head unit (2007 si sedan)
- i have an oem honda cd player and dont have the code
- Double Din Navigation = theft magnet?
- Clifford 3.5 dead not sure what's wrong.
- How to troubleshoot sub/amp combo
- alarm factory power locks
- help, how to install amp for mid's
- Quick question about dei 520T/507M
- 98 Accord -EX-L [Alarm does not stop on Jump Start]
- Dimmer switch wire
- need help!! just installed eg usdm rear speakers doesnt work searched!!
- Deck not working checked fuses
- what to expect from box change...
- q about power issues 91 accord
- Help! My wiring harness doesnt fit.
- taking out my radio
- 529T - Side one, ground when armed to close, can side 2 still open while alarm is armed?
- radio code help
- DEI 5900, how many useable outputs?
- Is stock electrical okay
- new 07 civic
- 6x9's into EG Hatch (already searched, no luck.)
- Wiring help, amp issues, keep blowing main wire fuse
- Adding a 6x9 in a 95 prelude
- make a hood release button
- Viper 5000 help
- how to install dvd/cd in a mdx
- Panasonic Headunit cutting out...
- window sensor replacement
- Actuators questions
- Just wanted to bounce off some security ideas..
- I just bought a "Police" siren. I need help installing it!
- Head unit was stolen - question about installing a replacement.
- alarm? alarm?? alarm??? !!!!!HELP!!!!!!!!!!!!!
- trouble shooting viper 5900 transmitter
- hissing from speakers with car off
- QUESTION ABOUT 6TH GEN ACCORD IN DASH GPS
- CC Install Gone Wrong...
- 99 Integra gsr hatch problem
- Blowing Dizzy Bad......
- Audiofonics and Performance Teknique any good?
- New front speakers
- FG2 Aftermarket ideas...
- Help-99 Integra driver side door lock sticking
- Help-99 GSR keyless entry problems
- Can the pioneer avic z2 fit in 01 civic sedan?
- OEM door lock witch and DEI actuators.
- Stock speaker grill
- Pioneer Premier Subs
- 07' Odyssey: Factory rear DVD system functioning after Aftermarket Cd install.
- Remote Start Alarm without installing remote start
- Installing Tweeters (Advice Needed)
- Trouble with installing Viper 5900 into 00' acura integra
- HOFCO ALARM PLEASE HELP!!!
- Invasion of privacy?
- Which Head Unit is Better and Why?
- What are Good speakers (6.5)? (BUDGET 400) GTA Location.
- 05honda accord need XM coverter to AUX cable.
- Radar Detectors
- Not A Honda - But Need Help With A Vehicle At Work
- integra antenna question
- Question about speaker
- subs cutting out after notch 15 on the volume?
- Need help with remote start
- need help on ebay alarm
- Speaker Size Question.
- I got a 2007 Accord SE--Now I need a system..
- big 3 alternator cable
- Question about Alpine AI-Net iPod adaptors
- help with wiring aftermarket radio
