Radio Died
My stock 01 ITR deck stop working. all the lights still turn on with cluster. Theft light still blinks. Check the 7.5amp fuse hood and the 10amp under dash. I also check for loose connections. any other things i can check
If the "Theft light" still blinks the 7.5A back up fuse, [constant power] is still good, the problem is the radio acc. fuse or circuit, as mentioned meter the fuse, it may look good but can be defective rather then blown, or just install a new or known working one.
Please do not install a bigger then called for fuse.
94
94
DeviousCTR
Aug 22, 2005 02:16 PM
