sub and amplifier
Old Apr 15, 2008 | 04:49 PM
blackrocky's Avatar
Default sub and amplifier
what things do i need to install a sub and amp. in my 08 si
Old Apr 15, 2008 | 04:54 PM
johnnycivic66's Avatar
Default Re: sub and amplifier (blackrocky)
This should probably go in the Audio section of the board.
I asked a similar question here:
https://honda-tech.com/zerothread?id=2264754
And as White Smoke pointed out, a search would probably turn up some results as well (which it will).
Good luck.
Old Apr 15, 2008 | 05:01 PM
blackrocky's Avatar
Default Re: sub and amplifier (johnnycivic66)
i want to keep the factory radio. i just want to add an amp and sub.
Old Apr 15, 2008 | 06:08 PM
RICO_'s Avatar
NO MERCY!
You'll need an interface to integrate the sub and amp into your factory head unit (ex. JL Clean Sweep).
You'll also need speaker wire for the sub (12 gauge), an Amp kit for the Amplifier (comes with ground and power gauge wire and the fuse), and a box for the sub.
That's basically it as far as I can tell.
Anybody else feel free to add in if I missed something.
Old Apr 16, 2008 | 07:46 AM
gus738's Avatar
Default Re: sub and amplifier (RICO_)
you can also loc it to rca > amp 8th civic has alot of great info regarding this sorry dont have links
Old Apr 16, 2008 | 08:09 AM
builthatch's Avatar
MiG-21 superfan
Default Re: sub and amplifier (gus738)
the interface i like is the MTX re-Q. it's pretty hassle free, easily adjusted, and easily installed. i use it in my mazdaspeed3 which has a factory bose w/ amped sub and it works well with the alpine amp, components and sub i added.
boostedjdmdc2
Audio / Security / Video
Feb 23, 2009 05:08 PM
WalkerGSR1
21
Feb 15, 2007 06:58 PM
JdM_RACeR07
Nov 19, 2006 04:02 PM
Giga Crusher
Dec 1, 2004 06:52 PM
ku09
12
Oct 8, 2002 06:27 PM
