- Gathers GPS?????
- my plans, help.
- Alarm Install did I get Screwed? A few Questions
- sometimes my alarm led won't blink when armed
- 91 Sedan Rear Speaker Help.
- All what I whated to do is zoom zoom in my boom boom =(
- big 3..where's the positive on the alternator?
- how can i hook up a battery disconnect switch.. (alarm problem)
- Glass Break Sensors
- Front or back speakers repalcement
- Front Speakers Only Work With High Volume
- Alarm Feature Question
- 05 double din install
- Cluster, Timer, Radio resets when i turn my 7th gen Civic off/on
- Need help w/ a DICE ipod kit (DC2 headunit)
- Show ur system!!
- Hey, i'm using a 96 teg cassette player in a 00 gsr.
- where is the antenna on '07 Si sedan
- Wiring problem somewhere - need some help.
- How old for MECP??
- Reducing 6 ohms to 4 ohms
- 95 LS Alarm questions
- What amp to buy?
- Check this out guys !!!!
- viper alarm working and sometimes not?
- 97 civic aftermarket stereo
- Stock Radio Issues Need Solved
- Alarm/Kill switch questions
- Whining sound when car is running
- Aftermarket foglight problem
- Is this a good security system?
- EK OEM Tweeter Pod Dimensions
- My Subs
- Del Sol rear speaker mounting depth?
- Cheap system for '00 Civic coupe?
- Power unlock disable guide???
- Speaker troubles
- Sub/Amp Recommendations?
- No power except to Hazards after Headgasket change!?
- Grounding Help 98 Civic!!
- Help with my power door locks!!!
- PIONEER AVIC D3 HELP
- i need advice/recommendations
- Help with Viper 5901 on '97 Accord
- anyone know what size speakers an 88 civic uses?
- headunit only has power if parklights are on!!!!!!!!!!!!!!
- new kenwood 6x9's making weird noise
- Adjusting alarm
- Turbo timer and Bypass relay How to disable shock and other sensors
- Car stereo problem
- 96 with 99-00 foglights wire installation???
- Folding key for Civic?
- Recommend me some speakers
- 6x9 only producing nothing but bass, need to know adjustments.
- Special alarm install ?????
- Pioneer Avic D1 opinions
- Subwoofer Problem
- terminal block
- 2002 Civic Alternator
- **okay so i've searched for this topic, and i can't find it! someone please help!!**
- Alpine Lock-Pin, Where to get?
- Sub Box Behind Strut Bar EK
- is this stereo jdm?
- Where To Buy A Really Loud Siren
- SRS light stays on after alarm install
- Will this head unit fit my car? Install cost?
- Motion sensor troubles with AU94TM by crimeguard with clifford alarm
- Car alarm comparison
- tight bass for my hatch !
- hard wire Ipod directly to speakers?!?!
- Where to get OEM remote??
- oem 92 civic hatch door speaker size?
- is my sub woofer blown?
- Integra alarms
- Installing Subs? 2000 Honda Civic EX Sedan
- keyless lock confusion???
- Check this out! a Real Old school amp..
- need help from the electrical guru's
- Autostart help please.
- Has anyone retrofited there Honda with an OEM Acura Bose system?
- Installing aftermarket radio, Do I really need the dash kit?
- Carrozzeria 6.5" JDM goodness
- my alarm wont chirp
- Help with sub
- 05 Radio Bezel
- Ipod cable for factory stereo
- 94 CIVIC AMP STEALTH
- Voltage problem + Audio Questions
- How to reset compustar brain modules?
- How to wire up windows up and down for 98 honda accord?
- Amp givin me problems help!!
- Building My System!
- Equalizer
- Need some help with alarm install into 97 Civic
- battery keeps going dead where to put battery switch?
- aftermarket steering wheel?
- best location for sub (92 hatch)
- What surprises me about all these stolen vehicles are..
- Viper 790XV woes
- What do you guys think of Dual?
- 97 prelude radio not working
- 2000 civic SI Keyless Entry Remotes Sync?
- Viper 5900 2way pager remote stopped transmitting
- Quick Question On Sound System..
- Retrofitting a NAV unit into CTR console?
- compustar remote issue
- Can't find Valet Button for Avital Security System
- 06' Civic AUX Port Install
- Honda Civic EG 92-95 Constant Power Wire
- Cd player shows error E-01
- Battery running low while using System - 04 CRV
- cd player and clock no longer getting power?
- prevent battery drainage
- Problem wit Clifford 50.7 alarm please help!!
- anybody know of any how too's?
- Python alarm problems - need help!
- immobiliser help newbie
- 91 crx 6x9 set up
- any possible way to fit 6x9s in the rear of a 95 4 door civic
- Can a Fm tranmitter (power by cigertte) be modded to power by cd deck?
- So my (refurbished) Clifford Matrix 12.5x alarm came in today...
- mounting depth of front speakers on a 95 civic
- are pbx speakers any good?
- List of good amps
- power for head unit question
- retrofitting a 2005 civic radio into a 1995 hatch.
- how to wireup a 12v power?
- My amp i just bought
- Speaker recommendation for my 1990 crx si
- difference between cliffard alarms
- viper 500esp
- integra help
- toner/tracer for cars?
- testing polarity - i thought it would be easier
- JVC KW-AVX720 Video Bypass
- radio,cigg lighter, and horn not working
- HELP! with ipod connection 2005 honda
- Battery relocation/bay wiring questions.
- 98 Civic Coupe Alarm Issues/Viper
- What hits the hardest
- What size are the OE speakers
- Need help installing 2nd cigarette adapter **PIC**
- Head lights dimming after new amp install
- Clifford Alarm and Setup Questions
- Bought a used car, alarm doesn't work?
- 01-05 keyless into a 96-00 please help! :)
- Clifford 50.5x problems
- 97 Accord OEM Stereo CD changer plug pinout
- What can cause an alarm to set off false warnings?
- need help - 2006 Honda Pilot DIY AUX input for 6 CD indash changer non NAV/RES
- Coolant Fluid Constantly Low, Idle Rough, JDM Navi AC A/C Heater
- Need urgent help!!! Locks and pass window not working
- Security Killswitch on constantly, cars stuck at store, need help!
- Help with a avital system
- Adjusting sensitivity on Code Alarm
- Subs cut out sometimes ???
- Amp to power 4 speakers and a bazooka tube?
- help!! 2000 acura tl.. alarm wont turn off
- What's the deal with this sub?
- Pioneer or Alpine
- clifford arrow 3 auto arm
- 2004 Odyssey add on single cd player
- Where can I buy connector pins for my headlight harness?
- If your good with Car Alarms, I need your help/thoughts...
- 6x9 speaker grille rattle
- JVC Headunit iPod Interface and Satellite Radio Interface Possible?
- audio interference (buzzing) noise HELP!!!!
- PRM-Main Relay Kill DIY How-to Write-up Diagram CauseforAlarm
- couple o ?s amp size?to speaker ratio?
- alarm question
- Clutch lock/ steering wheel quick release suggestion
- cd player install??
- Please help with this DIY Immobilizer I'm working on
- Ground Wire location for DC?
- Electrical weirdness, need help
- Stereo issues
- Subs not workin at all
- Trouble with speakers
- OEM Honda 6 Disc Changer into Older Honda Cars . . .
- installing tweeters. NEED HELP!
- tweeter install - 97 accord lx
- how do i get my JL sub out of the box..pics inside
- power lock noise after clifford install
- Directed 545T Nite Lite wiring help
- 95 civic Gauges don't turn on after alarm
- 1996 civic viper5900 alarm install door lock trouble..please help
- Alarm Suggestions....
- integra 4dr power locks
- Old System Woes
- Problem with alarm.
- no radio reception
- Unknown engine electrical problem..
- Subwoofer help
- Changing Radio Station Background Lighting Color
- hood pin switch problem
- Having trouble finding the right wires. driver priority unlock for honda accord
- Help Electrical problems! Locks and deck
- 91 Acura legend Radio Code
- Odyessey/99-00 Civic Si Radio wiring diagram
- 99 Acura 3.0 radio removal.
- How many watts can i run safetly
- looking to do a full stealth install
- Can you disable Honda Immobilizer?
- High pitch
- Shallow Subwoofer
- s2000 alarm help **URGENT** PLEASE
- JDM DC2/DB8 Climate Control in USDM Integra
- Subwoofer wiring (newb)
- Alternator problem fried my head unit?
- Hi need help please.
- Left Rear speaker out?
- my door lock isn't working!!!
- My EJ8 needs an IPOD
- which head unit are you currently using?
- Am I wiring my door locks correctly?
- L5 into Civic spare tire area
- How to build a sub box?
- Doing some research on cell phone based alarms
- Crackling noise in radio w/ A/C blower on
- "Pro-Start" auto starter/alarm not working properly
- Window tint help! Attn photoshoppers! :D
- ///Replacement remote for alarm?///
- Radar proximity sensor and animals?
- Engine Noise in Speakers...clarification.
- Single 10" or Dual 10"s?
- Sub recomendations
- save part of song as a short music file.
- Keeping Alarm Brain?!?! Who wired this crap.
- '94 Accord kill switch?
- Is this a decent alarm?
- Adding Tweeters
- Trunk Light Wire 95 Accord EX Sedan
- alarm isn't responding to either remotes.
- AVIC-Z1 troubles....I dont know wat else to do.
- Looking for an inexpensive Headunit with MP3/Aux
- Capacitor or No Capacitor?
- Has anyone with GPS get there car stolen?
- back to stock
- 100% lost on how to install this headunit...
- STUPID WINDSHIELD FLEX - 98 Civic 10,000 Watts 2 18's Rockford F
- alarm install on 4dr db8
- ATTN: Auto-Lock owners....
- What alarm has the longest range?
- video with out parking brake being applied???
- head unit wont work ...PLEASE HELP..details inside
- Installing Radio Reciever
- Alarm Issue
- System cuts out when volume past 20!??
- Shock Sensor wiring color codes. People who know what wire does what.
