make a hood release button
Old Apr 4, 2008 | 02:34 AM
sandturtle's Avatar
Default make a hood release button
anyone know how to hook up the hood release cable to the a door lock accuator so you can pop the hood with the push of a button? i really wanna try this but couldnt seam to find a D.I.Y.
Old Apr 4, 2008 | 05:02 AM
B18C_EJ8's Avatar
Doubtful that you'll be able to pull the hood latch with a door actuator.
You'd likely need a trunk pop solenoid.
Old Apr 4, 2008 | 02:35 PM
sandturtle's Avatar
no i no for a fact that they used a door lock accuator and wired it.. but i dont no what else they used to mount the cable to the accuator
Old Apr 4, 2008 | 02:52 PM
dopey88's Avatar
you will need 2 relays and wire them up for reverse polarity. on one relay wire 87/85 to 12 volts / 87a to ground / 86 to - lock trigger / 30 to the accuator/solinoid and on the other relay 87/86 to 12 volts / 87a to ground / 85 to - unlock trigger and 30 to the actuator. sorry i dont have a pic but that is how to wire them up.
Old Apr 4, 2008 | 03:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: (sandturtle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sandturtle &raquo;</TD></TR><TR><TD CLASS="quote">no i no for a fact that they used a door lock accuator </TD></TR></TABLE> Sorry, you may think you know but you are wrong, a door lock actuator does not have anywhere near enough torque to release the hood latch, take my word for it.
As mentioned you will need a solenoid. 94
Old Apr 4, 2008 | 04:24 PM
onelovebiker's Avatar
u can buy an aftermarket heavy duty accuator* n wire it up with a relay like dopey mentioned.. but using a oem door lock accuator would not be stronge enough ta pull tha hood releace.
Old Apr 4, 2008 | 06:40 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (onelovebiker)
And to save money all you need is one relay
Old Apr 4, 2008 | 08:08 PM
suspendedHatch's Avatar
Default Re: (wrx-killer-Sti-eater)
He's telling you how to wire it like a door lock. But unlock a door, you don't need to go in both directions. In other words, pulling the cable pops the hood, but pushing the handle the other way doesn't pull it closed again.
I found this diagram oh I don't know from where, my site I guess.
Instead of the red/white wire, you'll have a normally open push button switch connected to ground.
Be sure to fuse the constant 12v with a 10-15A fuse.
And yes, you'll need a heavy duty solenoid. An actuator isn't going to work.
Old Apr 5, 2008 | 03:03 PM
sandturtle's Avatar
Default Re: make a hood release button (sandturtle)
thanks for the replys.. suspendedhatch is the alarm wire necessary for the hood release?
Modified by sandturtle at 3:55 AM 4/6/2008
Old Apr 9, 2008 | 09:12 PM
JDM_NA_eg6's Avatar
only if you want to be able to pop the hood with your aftermarket alarm remote
Jul 30, 2018 06:48 AM
ej888
Audio / Security / Video
May 15, 2011 07:03 AM
1989 Honda Accord
Feb 7, 2007 08:43 AM
mswanson00
Apr 9, 2005 08:21 PM
bey
12
Aug 11, 2003 07:49 AM
