Funny thing with the stero.
Old Apr 8, 2008 | 08:29 PM
em1woot's Avatar
Default Funny thing with the stero.
Ok, so I bought this Blaupunkt (key west MP36). I connect the red and yellow from car to stero together cause thats how the stero has it. The stero turns on without the key and when I take off the face the music is still on for a few secconds then turns off.
So my question - is this normal?
Old Apr 8, 2008 | 09:18 PM
splmaster's Avatar
Default Re: Funny thing with the stero. (em1woot)
it sounds like you connected the 12volt switch wire, and the constant 12volt wire together. this would not be good and would drain your battery.
the head unit should NOT be on unless the car is on, or the key is in and turned back.
Old Apr 9, 2008 | 01:22 AM
schmiddr2's Avatar
It's not a problem. The lag time of the music could be the capacitors holing lots of charge or staying powered longer because it's wired for constant power. I had mine connected like this for years. If you forget to turn it off it will wear down your battery, but if your taking the face off then no problem. You can fix this problem if you want to.
Old Apr 9, 2008 | 04:28 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1woot &raquo;</TD></TR><TR><TD CLASS="quote">I connect the red and yellow from car to stero together cause thats how the stero has it.</TD></TR></TABLE>
You mean the red and yellow wire from the stereo you connected together? What's the M/M/Y of you car? Do you want the head unit to stay powered on when you turn the key off? The fact that the stereo stays on for a few seconds after you remove the fase plate is probably normal for that unit.
Old Apr 9, 2008 | 10:06 AM
em1woot's Avatar
Default Re: Funny thing with the stero. (White Smoke)
Its a 00 si, After I connected them together, I was like WTF, then I connected the red with red and yellow with yellow and the same thing happen
Old Apr 9, 2008 | 10:16 AM
i my honda
Global Mod
You have something hooked up wrong. Make sure yellow goes to yellow and red goes to red.... Check your connections again. The CD player should power down when you turn off the car.
Old Apr 9, 2008 | 11:09 AM
em1woot's Avatar
I connected this stero the same way i had the other stero was. I'll check the wires again. I always connect my own steros and this is the first one that this happens.
ERIC!
Mar 12, 2008 11:09 AM
slipage
Audio / Security / Video
Nov 13, 2005 09:10 PM
coupon
Jul 5, 2005 09:42 AM
E-Rok
Jul 11, 2003 07:52 AM
