big 3 alternator cable
Old Mar 27, 2008 | 11:46 AM
blackccoupe's Avatar
Default big 3 alternator cable
when you guys did this cable did you fuse it in between is it necessary to do that or will it be ok to just run the wire
Old Mar 27, 2008 | 12:19 PM
B18C_EJ8's Avatar
I believe that wire is fused in the main fuse box, so no, it's not really necessary to fuse it again.
Old Mar 27, 2008 | 12:34 PM
Default Re: (B18C_EJ8)
so i run the wire to the fuse box the the terminal on the battery?
Old Mar 27, 2008 | 01:11 PM
bpr0422's Avatar
Default Re: (blackccoupe)
The alt is directly connected to the main fuse box...
i think its the 2nd big wire coming out from it, one goes to the bat, the other goes to the alt...
if you are just adding a wire, its easier to connect it to the positive terminal on the battery, but if you are replacing it.. its cleaner to connect it to the fuse box, where the original wire was connected to...
Old Mar 27, 2008 | 01:16 PM
bseriescrxsi's Avatar
Default Re: (bpr0422)
that is correct when your positive lead comes off the battery one end goes to the starter and the other to the fuse box...after this it is fused with a 60 - 80 A fuse then the wire comes back out and goes to the alternator
Old Mar 27, 2008 | 01:33 PM
Default Re: (bseriescrxsi)
so if i run a new 4awg wire directly from the battery will it be ok non fused ?
Old Mar 27, 2008 | 04:11 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe &raquo;</TD></TR><TR><TD CLASS="quote">so if i run a new 4awg wire directly from the battery will it be ok non fused ?</TD></TR></TABLE> Directly from the batt. to where? 94
Old Mar 27, 2008 | 05:12 PM
Default Re: (fcm)
directly from the battery to the alternator yo
Old Mar 27, 2008 | 10:59 PM
i would never do that.....the fuse is there to protect the whole electric system...i wouldnt recommend taking it out nor would i ever on any of my cars
Old Mar 27, 2008 | 11:25 PM
bpr0422's Avatar
i don't think the oem fuses it...
there is a big metal plate connecting the two main wires in the fuse box...
so it should be fine...
edit: 96 fuse box image, stolen ^^ -thx RonJ
Old Mar 28, 2008 | 05:31 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe &raquo;</TD></TR><TR><TD CLASS="quote">directly from the battery to the alternator yo</TD></TR></TABLE> Why would you run a 4ga wire from the alt. to the batt., do you have a 150A alt.? 94
Old Mar 28, 2008 | 08:01 AM
Default Re: (fcm)
getting a 130 thanks bud haha
Old Mar 28, 2008 | 08:20 AM
adrian1281's Avatar
i always heard if you run a wire from the alt to the battery you should fuse it as close to the battery as possible. if you are getting a 130amp alt, fuse it with 120 or 125 for example. that way if the rectifier in the alt or something else goes bad, it won't fry the wire and possibly catch fire.
Old Mar 28, 2008 | 09:03 AM
Default Re: (adrian1281)
k thanks man
Old Mar 28, 2008 | 03:36 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe &raquo;</TD></TR><TR><TD CLASS="quote">getting a 130 thanks bud haha</TD></TR></TABLE> Then a 6ga cable is big enough although a 4ga can't hurt it gains you nothing.
A fuse is not needed.
The connection can be made at the stock location in the engine bay fuse box or the batt., the batt. is a better, [and easier] spot and connects the alt. directly to the amp power lead. 94 94
Heisenberg
18
Mar 8, 2015 07:16 AM
MUGENVX9
Honda Civic (2001 - 2005)
Jun 16, 2014 04:54 PM
DailyDriven259
May 11, 2012 11:31 AM
emooheo
Audio / Security / Video
11
Oct 6, 2010 05:53 AM
DynastyRacer22
11
Jan 28, 2005 06:04 PM
