Hooked up amp and sub but doesn't work.
Old Apr 29, 2008 | 03:30 PM
Hanmin's Avatar
Default Hooked up amp and sub but doesn't work.
When I took the system out of my other car it worked perfectly. The power light is on so my ground and power is good. The blue wire is hooked up to the deck, the 2 plug in wires is connected to the back of the deck too. And the last 2 wires is correctly connected to the sub. What can be wrong? I set my deck's sub level to max and the sub level on the amp to max. Still doesn't work.
Old Apr 29, 2008 | 03:53 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Hooked up amp and sub but doesn't work. (Hanmin)
You need to check the main battery fuse. Just because the amo is lighting up right does not mean its geting power. It could pull power from the remote lead. Did you test with a meter to see if the remote wire is putting out power? Did you do the same for the power wire? If not you need to check. Makse sure the sub leads did not come loose inside the enclosure
Old Apr 29, 2008 | 04:39 PM
Hanmin's Avatar
got it, the 2 plugs that plug from deck to amp came off. thanks.
NY's_Freshest
Audio / Security / Video
Mar 29, 2012 02:29 PM
White Boy Hatch
18
Jan 4, 2011 10:05 PM
White Boy Hatch
Jan 4, 2011 08:19 AM
Ziggie
Aug 22, 2003 03:23 PM
haloseven
Mar 12, 2002 07:21 PM
