- 2008 Civic DX Radio
- dash power wire crossing RCA to amp
- clifford 50.5x Remote ran out of batteries and now will not resync
- iPod PAC adapter for old alpine HU
- In-dash tv getting bad reception...
- 2004 Acura RSX Headunit
- Sub Grille
- Where online do you buy your stereo equpitment from?
- Mounting Alarm Antenna
- Alarm with backup batt. ONLY?
- Looking for a small and inexpensive sound system setup
- Radio in Accord SE
- installed new speaker made whole system no bass, high pitch
- HELP!! EK amber clock installation
- Getting a window tint that has HIGH Solar rejection but doesn't interfere with radio??
- viper 560xv into 94 integra gsr sedan
- *Help, Just bought Gather's Navi *
- Fiberglass Door Panels (in Progress, Pictures)
- new speakers & HU disappoint, should be better??
- New way to wire components
- 529T malfunction?
- Radio problem!!
- 8 ohm bridged vs. 2 ohm stereo
- door speakers
- Xm radio with stock LX HU
- AU94TM motion sensor with Scytek alarm help.
- Clifford Matrix 50.5x no paged recieved
- How Do I Know What Remote To Buy?
- Remote start viper 791xv instructions
- Integra Component Speaker Install
- crx alarm?
- What Car is This Head Unit From?
- radio problem????????
- Security Question
- 2007 Honda CRV Radio Code?
- Where to install sub in 00 hatch, needs to be hidden
- 06 Civic aftermarket
- Double-check my amp work PLEASE!
- JDM to EDM EG6 cluster needle swap, possible?
- 5h Gen Civic - Removed Radio - Storage Pocket?
- DECK INSTALLATION HELP!
- sub + amp install
- My Stereo Is LOCKED!
- sub doenst work .. wtfizuk!?!
- Uninstalled old alarm, car will start but wont run...
- Generic Keyless entry problems/identification
- Amp won't turn off
- Clifford Matrix 50.5x, car not "beeping"
- wiring mix up
- IPOD ?
- ED Sub blown
- electric charge the car to kill electronics?
- speakers that hit low?
- Blinkers stopped working... removed Alarm system
- Viper 5900 sst alarm reset/clear question
- BAZOOKA TUBE SUBS reviews
- Anyone heard of Metrik?
- Head Unit Trouble
- Why you don't need a capacitor.
- stereo just turnd off!
- Integra back up fuse problem
- 06 Civic dash lights
- sub is not bumping??
- charging capacitor
- Radio not working
- Aftermarket radio?
- removing the honda accord audio head unit
- 1994 integra turbo noise.
- Installed New Radio - Dash Lights Don't Work
- Viper 5900 Remote Replacement
- door key lock?????help asap please
- door trigger location on 92-95 civic
- subs killing battery but changed battery so does that mean i need a new alternator! help
- Avital Tornado wiring diagram
- add remote to viper 5900
- stereo works but no sound
- Do you need the remote lead to have an amp turn on??
- Antenna's
- HELP!! My reverse light won't turn off??
- '02 Coupe with Kenwood Head Unit - & Alarm question
- Suggested Amp????
- Alarm With GPS
- yesterday my new pioneer HU would'nt turn on?? also my clock is dark???
- Wiring Issue on 90 CRX dx, Please help
- avic n1 navigation cd work with avic n2??
- Amp Trouble...
- sub box
- DEI528T Help
- Question about full-ranged speaker
- pac ipod adapter for old alpine stereo deck
- In Need of an alarm for my ITR. Viper/Compustar Pro/Clifford.
- Is this possible?
- 07 accord dvd navigation player
- Clifford Alarm remote died,not communicating with brain
- CD player magically stopped working
- Noisy tape deck
- Looking for component speakers
- Shifter/Gear Lock???????
- 2 12" subs burned, is it possible?
- Alarm hood pin options
- Can I upgrade to a 4-button remote? (python 460hp)
- does this amp make a good pair with this sub?
- Amplifier Power and Heat question
- Need help installing Viper Alarm/Remote Start system on 2000 SI!
- When replacing the alarm's remote battery... will it reset?
- Help. Programing clifford remote
- Head-Unit Troubles
- 2 Qs: What sub setup for rock/metal? & Alpine fitment
- starting issue after kill switch install
- hood release actuator?
- wiring JL W6V2...
- autotek mx1500
- Running a 2001 Accord without alternator?
- Installing a Remote Start/Unlock Kit, Need some guidance
- new head unit & speakers, still sounds like crap ???
- stereo in eg jdm center console??
- JL Audio
- OEM deck VS. Aftermarket deck
- sony xplod deck cdxmp70
- How to find bad component on guitar amp circuit board?
- Alarm system/Karr
- Back Panel Rattling
- Buddy opened my car with a random key! Combat problem?
- Whats the purpose of foam in subwoofers?
- Please help, can't figure this out.
- How do i connnect a fan to my amp?
- Moving my headunit into my lower cupholder unit... Have parts, does not fit!
- 99 civic front speaker cover not fitting
- Subwoofer problems
- Fiberglass Dash Piece Project (pictures)
- alpine remote ?
- custom speaker grills
- Alarm issue, doors not locking
- anither DIY alarm problem
- Amp on, no sound from subs
- Settings on system? Help =/
- recommend me a sound system! :)
- Trouble installing OEM cd Player in my CD5 Help!
- help figure out air space...
- opinions on hornet alarm 740t? what else should i add for security?
- painful siren for in cabin?
- 94 civic speaker size question
- 1992 honda accord door speakers
- Sub just vibrating
- car alarm problems
- Subs wont turn on
- Any Alpine Dealers / Reps? KTP-445 Power Pack Upgrade?
- help with install indashnavi civic si 2006
- Alarm Draining battery when off. Maybe
- viper 5900 sst problem
- Want to Upgrade My speakers
- Factory Alarm remote
- compustar??keyless start??
- JDM Sat Nav
- Accord car computer
- subs
- What is stock power output for a Honda OEM plain radio/CD for 2002?
- No sound from new speaker
- horn ouput (- 250mA) from alarm rerouted through a relay to a 12v siren? cm4200 (install pdf link)
- alpine 9835 wont play sub on cd mode just stereo mode! please help
- Must be a ground as harness is showing 12v for 2 wires, Please HELP!
- Integra stereo harness ?
- What Amp to buy? capacitor?
- FACE FOR A PIONEER FLIP UP
- DIY: Custom Speaker Pods and Tweeter Mounts for my SR6500 components
- Window Laminates - another layer for anti-theft?
- need help with my clifford AVG5. manual program
- Installation kit for 92-95 civic
- I think my Head Unit finally took a crap, HELP!
- radio
- Alarm enabled push to start button
- plz. help (honda accord 1999)
- Anyway to make slim jimming a 96 Accord more difficult?
- "Armored" non-stealth alarm install
- jdm climate control-2
- Indash DVD pop out monitor
- LED's on a 12V source. resistors?
- Rca cable
- Subwoofer doesn't work.
- 93 Civic kill switch?
- External crossovers
- what should i get?..help me out
- Does the 03 accord stock stero have RCA conections?
- 2000 accord coupe, where to run the power wire through the firewall??? help please
- car shuts off after installing audio system.
- Wierd problem!
- older Alpine crossovers
- quick release + quick release lock + power steering removal = effective security?
- 03 civic help-noob question
- Garage Security - Low Cost Options?
- Keep fan running when car is turned off
- clifford 50.5x Turbotimer /remote start problems
- Problem with AU94TM
- Rear Speakers in a 4dr Civic
- bass enclosure
- Amplifier fuse keeps blowing... Haven't changed the setup in over 5 years.
- 90-93 Accord how-to amp wire through firewall...
- 93 Accord Amp wire through firewall..
- Opinion needed on Alarms from COMPUSTAR
- kicker L7s need some help
- Subwoofer humming.
- help with this sound system setup
- my doors lock and unlock randomly. whats wong?
- Using OEM switches for Start kills / Fuel cutoff, etc.
- Power Lock security device
- SPS-17C2 or SPS-600?
- master disconnect switch
- factory alarm - not for a honda
- TRYIN TO INSTAL A DVD DASH
- Could my wiring kit go bad?
- pyle fm modulator
- ok ok need some help on my audio
- Im a total noob when it comes to audio.... but i want better quality sound now. please help
- to run or not to run a amp...
- RHINO wheel imobilizer Issue !!
- Rockford Fostgate - Punch 5x7 ...any good?
- Buy a dual 2 x 12" box or just buy another single box
- Capacitor's pointless????
- 02 accord no illmination
- will stock wiring work with amp?
- Main relay kill switch
- Need help installing Alpine Type S Speakers.
- which size alternator...
- 95 accord power wire
- Cu. ft.
- fcm .. how much to disable my alarm???
- Installing an OEM S2000 (s2k) keyless entry into an Integra or Civic
- Honda Civic Hybrid 06
- No power to Radio/no lights for my speedometer HELP!
- looking for the vss wire, 94 integra
- Keeping the stereo on after the key is removed?
- Cd player, Horn, cluster, a/c lights dont work or turn on?
- tweaters to speakers???
- viper security system question...
- Maat security systems?
- Wiring up amp
- Pioneer DEH-P7000BT. Does anyone have any experience with it.
- head unit will not work what am i forgetting
- Radio is DRIVING ME CRAZY!!!
- Im thinking fit a new alarm with remote start ...but..
- Wiring my subs
- anyone else have the python alarm?
- Sub and Amp troubless..
- Kill Switch question.
- Converting Bose speakers for home use?
- CD slot ate disc!
- Popping noise coming from speakers after installing cd player in RSX
- Automatic Unlock
- Removing Factory Stereo - 1997 Accord EX
- radio wont work
