connect 2 amps?
Old Apr 18, 2008 | 09:52 PM
Keangdawizes's Avatar
Default connect 2 amps?
i'm sorry but if there's a thread about this or similar but link me if there is any.... well what i want to do is connect 2 amps. 1 for my sub and 1 for my speakers. i know how to connect a basic 1 amp but i'm confused and not sure how to connect 2 amp. how would i run the power, ground, remote, and the rca wires?? do i connect it to my other amp or what do i do?? can someone explain and show a diahgram or something please. thank you
Old Apr 19, 2008 | 09:18 AM
fcm's Avatar
fcm
Old Fart
Default Re: connect 2 amps? (Keangdawizes)
Need more info, makes and models of HU and amps.
The best way to power the amps is to run the appropriate power cable, [gauge] for each amp, [from the batt.] ground the amps to the same ground point, [floor pan of car] again, with the proper gauge cable.
RCAs should be run from the HU down the center of the car to each amp, the amp control lead, [remote] can be "daisy-chained" from one amp to the other.
Don't forget to "beef up" at least the batt. to chassis ground. 94
Old Apr 20, 2008 | 10:25 PM
EddieLe76's Avatar
to simplify your the power portion of that- run one single power cable down from the battery, and use a distribution block to give you two different leads.
Old Apr 21, 2008 | 07:29 AM
spivt11's Avatar
* B A N N E D *
Default Re: connect 2 amps? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Need more info, makes and models of HU and amps.
Don't forget to "beef up" at least the batt. to chassis ground. 94</TD></TR></TABLE>
what do you mean by beef up, to what gauge wire do you mean?
Old Apr 21, 2008 | 10:27 AM
fcm's Avatar
fcm
Old Fart
Default Re: connect 2 amps? (spivt11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spivt11 &raquo;</TD></TR><TR><TD CLASS="quote">
what do you mean by beef up, to what gauge wire do you mean?</TD></TR></TABLE> At least a gauge thick enough to match the amp grounds.
In the above case a 4ga - 2ga from the batt. neg.(-) to the chassis, [shock tower stud]. 94
Old Apr 25, 2008 | 10:30 PM
Jirro91's Avatar
why not go to the local stereo shop and buy power wire splitter "u feed the main line from the battery and spit it from there to the two amp's O_O"
*edit* what i did on my ef was took the remote hooked it up to one amp the from that amp jumped it to the other amp as for ground find a place for each amp dont ground both amps to the same place , b/c the amps might shut off if the stereo hits to hard
*just my 2cents*
Modified by Jirro91 at 11:36 PM 4/25/2008
Old Apr 28, 2008 | 09:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Jirro91)
Although a splitter/fuse block will work, it is not the best way to do it, separate power leads for the low-pass amp and high-pass amp(s) is a much better way to go for a few reasons, one being you eliminate all the connections, [resistance] of the splitter/fuse block, [up to 8].
Another has to do with "electricity takes the course of least resistance", running a sub amps own power lead directly to the batt. will prevent the sub amp drawing power from the high-pass amps power supply when hitting hard.
As for the grounds for the amps, they should always be grounded to the same point whenever possible, it will prevent ground loops 94
thebleek
Audio / Security / Video
12
Apr 3, 2009 10:46 AM
hcivic99
Oct 13, 2006 09:03 AM
MilanoCivic97
18
Mar 23, 2006 07:02 PM
95TEG
Oct 7, 2003 10:53 PM
SuperMan19
Mar 28, 2002 08:46 AM
