99 Integra gsr hatch problem
Old Mar 31, 2008 | 07:58 PM
adhuot01's Avatar
Default 99 Integra gsr hatch problem
Using the unlock button on driver/passenger doors will not unlock the hatch lock, I can hear the actuator click but it never unlocks the hatch. I have to use the key to open it, and 80 percent of the time I have to keep the key turned while I slide the lever to open it. Could this be a mechanical problem, in which I can lube, clean or allign the mechanism or is it electrical such as a relay or solenoid?
Old Apr 1, 2008 | 04:47 AM
B18C_EJ8's Avatar
Default Re: 99 Integra gsr hatch problem (adhuot01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adhuot01 &raquo;</TD></TR><TR><TD CLASS="quote"> Could this be a mechanical problem, in which I can lube, clean or allign the mechanism </TD></TR></TABLE>
Probably. Pull the plastic panel(s) and check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adhuot01 &raquo;</TD></TR><TR><TD CLASS="quote"> or is it electrical such as a relay or solenoid?</TD></TR></TABLE>
If you can hear the solenoid activating, then probably not.
M7EG6
Oct 29, 2007 12:32 AM
ericlee303
Aug 9, 2006 06:21 AM
EL Vap133
Mar 30, 2006 03:43 PM
RuskeR
Aug 23, 2005 09:40 AM
steven975
Oct 5, 2004 10:28 PM
