- Head Unit
- Front Door Speakers
- Right speakers not working, only left
- in need help, Necesito ayuda
- right front speaker not working
- PUSH BUTTON START
- Isobaric Loading
- Q's on ek/ef sound systems.
- do wheel boots work??
- Effective kill Switch
- HELP VIPER 5002 ALARM, TRUNK/HOOD PIN OPEN ??
- Well i finally did it.
- Need help with DIY imobiliser
- Killswitch on 95 Accord
- Looking to get these opionions?
- Hidden gem- 700 watts clean rms power for $99?
- Transponder Bypass?
- suggest some speakers
- 2000 accord. stereo is locked?
- does anyone know the exact tweeter size that comes in a 2001 chevy blazer(suv)??
- Problem fitting double-din into 99-00 Civic
- car alarm broke doors stuck locked
- Alarm help: How hard is it to remove my 791xv???
- C D Stuck in player
- Need help with covering box w/ carpet
- NEED HELP Pioneer CD-BTB200 Bluetooth Microphone Install
- 250W AMP + sub? total noob.
- PITA non typical or beginner charging system problems.
- weird issue with car alarm and ignition
- Amp Not Turning On.....wtf
- My new system
- ok my amps got power it turns on but now the signal is not get to the sub.....
- speaker set up for EG
- GPS IN-DASH
- location of remote starter?
- Dead Stereo
- My Fuse Holder Box melted?
- light weight space saving baSS
- 6x9's
- Car is finally hooked up stealth mode, thanks wrx-killer!!!
- Zoombak gps tracking device???
- Just bought a new amp, and now its not receiving power any ideas guys???
- Remote Paging System?
- Clifford Blackjax w/ Starting Issues
- cd jam, plz help
- Compustar remote backlight no longer works?
- Best Sub Wiring??
- Stereo Advice
- shitty stealth alaram install
- Advice with overpowering bass
- alarm siren
- whats better?
- ignition harness question
- Any great recomendation on anti-theft devices?
- SLENCER CAR ALARM HELP...
- 2000 civic oem speakers
- Heads up, good deal on JVC KD-SH1000
- Anybody ever use this amp... Any good?
- Should Amp RMS Match Sub RMS?
- Question on an amp
- How to Disconnect the doors from opening from the outside??
- static noise when braking
- Pioneer Premiere DEH680MP question
- Just finished my splits up front in my EG9
- Advice on amp
- DEI alarm help please
- nrg quick realease DIY?
- Why doesn't my Viper alarm work at high altitudes?
- clutch/alarm set up
- sub/amp issues
- Wanting to buy new speakers for front and rear
- How do I get my Viper alarm out of valet?
- 06 accord ex moon/sun roof control by 529T
- radio problem need help
- civic radio mounting kit
- How to wire up a 5 wire actuator Dei 524f ?
- Remote starter - What all do I need?
- starter kill with pass window up???
- Sub Amp. Help
- Anyone know anything about car audio for a Miata?
- cadence amp?
- oem cd player into 92-95 civic
- Looking for Python 950 installation manual ?
- Poll: Which grill looks the best?
- Help me with wiring (Amplify front speakers)?
- radio power wire??
- Do sound systems contribute to my gas decreasing?
- AVIC-Z2 Questions...
- S2000 Cluster in EK
- Viper 3002 Help (Crx and installing power doors)
- Working on new system. Questions, discussion, advice all welcome
- What are the best 6.5 speakers????
- Anyone here have a Del Sol with a sub install...
- Stop alarm from automatically locking doors?
- Ignition wire of alarm?
- Door Lock Problem with Viper 5900
- help with sub problem.
- HOW TO make your own camera mount for $5. (2006+ Si)
- Alarms and Horn sirens.. Can they be swapped?
- Problem with Viper 5900 install
- Complete kill switch (safty switch?)
- fuel pump kill switch
- 2005 Acura RSX factory alarm problem
- '95 Civic Coupe Tweeter
- Easy question about wiring 4 channel amp
- Popping sound when changing songs?
- What do you guys think of these components?
- amp wiring kit question about running the power cable into bay 03 civic si
- Alarm Problem
- Installing My Own Alarm?
- Kicker L5 vented truck wedge box vs. vented square box
- Dashboard Dimmer Light
- What size front speaker?
- Single Din/ Double Din
- door lock problems??????????
- Speaker Troubleshooting
- And so it begins.
- Need Help! Viper 5002 Door Lock Actuator Wiring!
- Anyone put 6.5" Subs in the rear speaker locations?
- i need help with pioneer avh 5000
- Feedback on these subs and amp im getting??
- rear speaker Picture request.
- im tired of seeing your cars stolen try this!!
- Bought a car with an alarm but no remotes....
- cheap rs ????
- AVIC-F700BT / D3.. which in dash to choose...
- Fiberglass Door Panel Piece (in Progress, Pictures)
- Need help with first alarm install.
- 2009 Accord with amp. I NEED WIRE COLORS
- teg wont start, alarm issue?
- Friends Car is Possessed, Radio issues.
- crv stereo problem
- Reccomend Me Some Component Speakers And A In Dash TV Head Unit
- AVIC-F series and iPod Touch 2.0 problem
- Auto-matic door locks
- cy-vmd9000u button removal
- anyone here use winisd?
- How to: Video Bypass wiring to Alpine monitor harness
- 508D.. dual zone motion sensor
- Normally open starter kill
- is this a good ground wiring place?
- Underrated Amps?
- quick realease pedals?
- Half my speakers just went out Plz HELP!
- ECU Removal Questions
- How to tell if amplifier is broken
- Install of a Piezo Mini Siren
- legit source for custom tuned ported box?
- Remote not working with alarm
- Help w/a Pioneer DEH-P740MP headunit (will not turn on)
- amp and sub wiring help!!!!!!!!
- Possibly a bad alarm remote?
- S2000 Alarm Problem
- Factory security system not arming, but the keyless entry works
- Viper Remote control..
- has any body put 2 15's in a prelude
- Pioneer Questions
- Viper 5900 alarm and Constant IG. blown [under SW] problem
- FUEL AND CLUTCH KILLSWITCH
- 1996 honda civic stereo configuration
- Best way to wire 4 ohm with 2 channel amp
- Flip down screen
- Metra Hidden Antenna HU wire color?
- My new favorite show
- Whine from speaker increases with rpm?
- compuSTAR 2w900FMR won't work
- Subwoofer at one constant volume.
- question about 6th gen radio in 5th gen.
- Need an alarm with sensitive shock sensor (possibly adjustable) on doors / perimeter
- Need Help! Radio Code for Civic.
- tach signal???
- all lights pulsate?
- alarm problem....
- '96 Acura Integra 2DR speaker set-up - Help please
- use a Cell phone as LO Jack
- kill switch
- Multiple sirens question/clarification...
- rear speaker set up. lets see them.
- What am I missing for this alarm?
- busted amp.... and amp stolen...
- 94 Accord antenna
- low charging with all of my audio crap..
- Which Harness to buy for this Head Unit?
- alarm wont stop
- Why does my radio reset itself?
- Help me decide what amp
- Just want some clean sound
- rockford fosgate p300.1
- '97 CX hatch radio relocate
- wrx-killer-Sti-eater stole my screwdriver!
- capacitor question
- GUIDEPOINT OR LO-JACK?
- Dead Alarm due to Jump Start
- weak bass
- A couple questions about alarm install
- Viper 5701
- gauge power cable!!
- Replacing Already Aftermarket Headunit 1996 Civic
- Sub and Amp question ?
- Is this the right way to wire a relay?! SECURITY GURUS!!!
- Swap out base stereo in RSX '05 prem. w/ the 6 CD version - what years are compatible?
- viper(791XV), how do i wire the neutral thing and the remote start?
- My subs just don't "sound right" ... looking for advice
- remote start help!!!
- Wiring dual stage prox sensor with OEM S2000 Alarm
- sub help
- Installing door lock actuators
- My alarm build thread
- where do u put a amp in a Del sol?
- Sub w/ Factory Bose System in a 97 cl 3.0
- need help and some ideas
- Wiring old deck...help.
- Alpine, 6 disc CD changer missing vocals up front
- Amplifiying Speaker Help
- ******* sub install on 1991 civic SI w/ stock deck **********
- current leak (head unit)
- How do I wire a hatch trigger?
- How to Install aftermarket stereo?
- Need help with audio... subs are not working
- Speaker Baffles
- 2007 accord sub install
- how can i make my car more secure? any tips besides alarm?!
- need some help on audiovox AA-925
- in dash DVD brake wire question
- Viper 1002 H1/12 orange wire
- How do i put my own sub system in an 08 honda civic?
- how do i switch alarm from passive to active?
- help with stereo
- No Audio Sound
- need help wiring up my own sound system
- Key Fob for 1999 Accord
- Subs cancelling each other out??
- steering wheel swap
- TOP 5 SECURITY TECHNIQUES
- Need help knowing what gauge power wiring to use.
- Need help shopping for speakers
- Center console swap/conversion
- AMP Advice ?
- need help with factory alarm removal!! please 98' civic dx
- Need fast response: installing a new head unit
- need some clarification
- Need some more advice
- Steering Wheel Volume Controls
- Cut Radio Harness!!!
- what to do, what to do.....
- Alarm stopped working? Or Remote Lost sync?
- no radio reception with HIDs on
- battery problems... car wont start after a few hours
- Harness to make HU's plug and play?
- Help with stock Integra stereo/cd player.
