Low pass filter
Old Apr 15, 2008 | 12:23 PM
deerman2701's Avatar
Default Low pass filter
So i was messing around with my head unit and got to this option called lpf "low pass filter". I have pioneer front door speakers and stock back ones with a single 4 ohm pioneer sub and bazooka amp. My question is what should i set the head unit lpf too. THe options are 80/120/160/through hz. Thanks.
Old Apr 15, 2008 | 12:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: Low pass filter (deerman2701)
Set it to what sounds best, but turn off the x-over on the amp, [set to full-range]. 94
Old Apr 15, 2008 | 06:55 PM
02 accord's Avatar
63 works for me.
Old Apr 15, 2008 | 08:59 PM
baller status's Avatar
Set it pretty close to what you have your sub amp set to. You want the sub to play maybe 100 and below, and the other speakers to pick up everything above.
Sucks that yours jumps from 80 to 120. Why is there even 160 available? You'll probably end up setting it to 80, but as fcm alluded to, trust your ears, not the internet.
You only use it if you have a sub. Cut the bass frequencies out from the door speakers and they sound so much better.
Old Apr 16, 2008 | 05:34 AM
Acidcrakker's Avatar
Default Re: Low pass filter (baller status)
Where is the low pass filter for, is it for all speakers, or just the sub output?
Id probally put it at 80, cause pretty much anything over 80 is considered mids.
Id go with the low pass filter on the Sub only.
Old Apr 16, 2008 | 06:04 AM
fcm's Avatar
fcm
Old Fart
Default Re: Low pass filter (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Where is the low pass filter for, is it for all speakers, or just the sub output?
Id go with the low pass filter on the Sub only.</TD></TR></TABLE>
Actually frequencies between 20Hz and 125Hz would be considered sub bass and up to about 500Hz-600Hz would be considered bass, mid-range would be between the 500Hz-600Hz to around 12kHz and highs to 20kHz. 94
Old Apr 16, 2008 | 06:09 AM
02 accord's Avatar
Default Re: Low pass filter (fcm)
Below 20hz is where the good stuff is. How could you leave that out?
Old Apr 16, 2008 | 10:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: Low pass filter (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Below 20hz is where the good stuff is. How could you leave that out? </TD></TR></TABLE> Well sure, if your an elephant, we as humans hear frequencies between 20Hz and 20,000Hz. 94
Old Apr 16, 2008 | 10:51 AM
02 accord's Avatar
And we, as humans, feel frequencies between 1Hz and ~120Hz. Feeling the music greatly adds to the experience.
Old Apr 16, 2008 | 11:04 AM
nsxxtreme's Avatar
As mentioned if you use the crossover in the deck make sure the one on the amplifier is off or set to full range.
Old Apr 16, 2008 | 11:41 AM
md88hfcrx's Avatar
i have a pioneer 6500 and boston speakers all around with a cheap ($40) sub setup
i set my amp to full range and set my lpf to 125 so it will hit the higher bass notes. my 6500 doesnt offer the 160 so i would set to to 120 or 160.
i keep the hpf set at either 80 or 125 and everything sounds good
prolly going to upgrade the full range boston subs because i like to hear the full range of the bass guitar for rock music
Old Apr 16, 2008 | 12:28 PM
nsxxtreme's Avatar
Default Re: Low pass filter (md88hfcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md88hfcrx &raquo;</TD></TR><TR><TD CLASS="quote">prolly going to upgrade the full range boston subs because i like to hear the full range of the bass guitar for rock music</TD></TR></TABLE>
Sound is subjective but here is why you would not want to do that.
Sub bass is omni-directional. This means that it doesn't really matter where you place a subwoofer because you can't spacially tell where that sound is comming from.
Bass notes and higher are not omni-directional the higher you go up in frequency the easier it is to pin point where that sound is comming from. If you have full range subs (which I have never heard of) and you place the woofer in the rear of your car it will sound funny. JMO
Short Fuse
Audio / Security / Video
16
Nov 2, 2004 06:55 PM
RiceRacist
Oct 17, 2003 03:02 PM
Bubble Gum Jr.
Apr 28, 2003 11:52 AM
Mike D
May 6, 2002 01:34 PM
Zulu888
Sep 8, 2001 10:43 AM
