problem with amp.....help please!!!!!
Old Apr 13, 2008 | 09:49 AM
Keangdawizes's Avatar
Default problem with amp.....help please!!!!!
i have a kenwood kac-7202 amplifier. well the problem with it is that it don't work anymore. the light on it keep blinking when it suppose to stay on. i think its on protection mode. is there anyway i can get out of it?? or if thats the end of my amp? help me please thank you
Old Apr 13, 2008 | 10:16 AM
94_DC4's Avatar
Default Re: problem with amp.....help please!!!!! (Keangdawizes)
Is the power light blinking or is the protection mode light blinking? Try replacing the fuse on the power wire for the amp. If the amp is still doing the same thing after you replace the fuse then disconnect the speaker wires and see if the light is still blinks.
Old Apr 14, 2008 | 12:06 PM
any other suggestion please?? thank you
Old Apr 16, 2008 | 02:47 PM
bsykes118's Avatar
the only problems that i see a lot with kenwood is that if you have the wires tucked under the amp and you screw it down real tight for some reason it pushes on the back panel and and causes the amp to cut out. if not that check the fuses in the amp (it probably isn't that since the lights are blinking) and try disconnecting everything and then connect just the power wires back and see if it still does it, hope this helps.
Old Jun 1, 2008 | 11:27 PM
FobFobFob's Avatar
https://honda-tech.com/zerothread?id=2293302 this could help....
Old Jun 4, 2008 | 08:09 AM
standbackimapro's Avatar
Just Disconect the subs, Because the subs could be bad causing the amp to go into protect, disconnect the rcas, because the fault can be comming from the out puts on the head unit or rca wires
so if u have the speakers unplugged, and rcas, and its still in protect, check the ground and wires
deerman2701
Audio / Security / Video
15
Jun 11, 2008 05:51 AM
muhaMan
Aug 12, 2007 09:33 PM
b18bteg14
Jan 10, 2007 07:29 PM
EBP_SI
Apr 29, 2003 02:55 PM
BoroDB8
Oct 15, 2001 01:09 AM
