791xv pager problem
Old Apr 16, 2008 | 04:25 PM
flatblack-h22's Avatar
Default 791xv pager problem
i am having problems w/ my pager. when the alarm goes off, i am not being paged that it is going off, what maybe the problem?
Old Apr 16, 2008 | 04:37 PM
fcm's Avatar
fcm
Old Fart
Default Re: 791xv pager problem (flatblack-h22)
Do all the other functions work? 94
Old Apr 16, 2008 | 04:47 PM
Default Re: 791xv pager problem (fcm)
arm, unarm, hood pins ect? yes
Old Apr 16, 2008 | 11:19 PM
WickedKP's Avatar
it sounds like you turned the paging part off.
hit the program button behind on the remote
wait for beep.
then press * to turn on or off.
wait 5 seconds to exit programing mode.
arm alarm set it off and see if you get a page.
some customers end up turning off by mistake.
if this dosen't solve try reprograming the remote to the alarm.
Old Apr 17, 2008 | 05:49 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblack-h22 &raquo;</TD></TR><TR><TD CLASS="quote">arm, unarm, hood pins ect? yes</TD></TR></TABLE> Then, ditto the above. 94
Old Apr 17, 2008 | 01:16 PM
Default Re: 791xv pager problem (WickedKP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedKP &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you turned the paging part off.
wait for beep.
how many time is it suppose to beep? it shows the status after i stop the alarm from going off.b also the signal indicator pops up a few seconds after some actions,.
Modified by flatblack-h22 at 7:22 PM 4/17/2008
Old Apr 17, 2008 | 10:29 PM
WickedKP's Avatar
I believe 1 chirp is on 2 chirp is off. if you turn the page mode off you will not receive the status until you disarm the arm. reason to make the battery in the remote last longer.
Old Jul 7, 2011 | 12:43 PM
HOODWORKZ's Avatar
Im having this same problem and I hear the beeps and it still does not page remote can anyone help
Originally Posted by WickedKP
it sounds like you turned the paging part off.lp
wait for beep.
Old Jul 9, 2011 | 05:25 PM
Cobb2819's Avatar
is the little antenna icon blinking in the top left corner of the remote?
Old Jul 11, 2011 | 06:57 AM
rjr162's Avatar
It could also be a bad remote (790s were prone to this issue)
esoterEK..
Audio / Security / Video
May 28, 2008 06:18 PM
HONDRETTI
May 6, 2008 08:04 AM
dfoxengr
Feb 27, 2008 06:10 AM
EeeJayEight
12
Feb 8, 2005 06:27 AM
clm
Oct 12, 2004 07:20 AM
