Good combonation?
Old Apr 19, 2008 | 05:55 AM
deerman2701's Avatar
Default Good combonation?
Ok so i am thinking about getting these 2 things for my car, take a look tell me what you think. http://www.crutchfield.com/App..._info and http://www.crutchfield.com/App...PM500 Right now im running a single sub and want more, the only thing i dunno is that the 2 subs are i think 8 ohm and there is only one place for the speaker wire but 2 subs? Im new to this so thanks for the help.
Old Apr 19, 2008 | 09:04 AM
B18C_EJ8's Avatar
RMS power handling on those subs/box is 100-300 watts.
The amp you linked will provide 300W at 4 ohms, so yes, they would work fine together.
Old Apr 19, 2008 | 09:08 AM
fcm's Avatar
fcm
Old Fart
Default Re: Good combonation? (deerman2701)
I will work just fine, continuous power handling of the subs is 300W and the RMS output of the amp is 1x300 RMS into 4 ohms.
The discription of the subs is two SVC 8 ohm speakers but the box is described as 4 ohms, meaning the subs habe been wired in parallel already and you will find only one binding post, [pos.(+) and neg.(-)] on the box. 94
Old Apr 19, 2008 | 09:42 AM
Ok cool so would u recommend this setup or buy two 4 ohm that have 2 sets of negative and positive terminals with a 2 channel amp or would there be no noticable difference.
Old Apr 19, 2008 | 03:47 PM
fcm's Avatar
fcm
Old Fart
Stick with what you got, sub bass should be run in mono off a mono block sub amp, the number of "terminals" makes no difference, what is important is that the amp has the RMS watts to match the subs continuous power handling, [RMS] and that the subs can be wired to match the amps rated RMS output.
In this case the box you link is wired to 4 ohms, [two 8 ohm speakers wired in parallel] it is rated at 300W continuous, the amp makes 1x300W RMS into a 4 ohm load, a very good match. 94
Old Apr 19, 2008 | 04:16 PM
B and B's Avatar
Loved
Community Favorite
Default Re: Good combonation? (fcm)
fcm pm'd
Jay J
Audio / Security / Video
13
May 7, 2010 10:43 AM
vtec8804
Apr 19, 2007 11:58 AM
N1NjA TuRtLE
Sep 25, 2006 05:21 PM
redline201
May 25, 2006 08:58 AM
Jacen
Aug 23, 2005 10:46 AM
