VSA and Power Steering Light on
Hi:
I have a 2013 civic coupe and two days ago I have to install the spare tire, after that the VSA Light came on and I though that it was ok due to the small tire size.
I installed a 4 new tires. The light for VSA system still on and the Check power steering system also.
Can anybody tell me what the problem can be? And could these lights be reset?
Thanks for the help.
PS:Nice site.
PS:Nice site.
Re: VSA and Power Steering Light on
First thing is first, you should never put the spare donut on the front. You move the back wheel to the front and then put the donut on the back.
Not only for safety but also so you don't cause damage to the transaxle etc.
The donut on the front is what probably threw those codes and you will likely have to slap a code scanner on the car to clear the codes once the tires are correct on the front.
Codes don't tend to clear themselves once set from my experience so far (2007 here).
Try doing a hard reset. Take both the positive batt cable & negative batt cable zip tie them together for 5 mins or so and then reconnect them. While doing this don’t let the cables touch the post of the battery.
silver_flash99
06-18-2007 02:32 PM
