2006 honda civic
2006 honda civic
replaced compressor - condensor --- refilled system --- everything works perfect ... stopped the car ... when re-starting no ac ... the only way it starts if i reset the a/c control .... and no codes present in the control ... stop the car ... after 10 minutes or so if i dont reset the control ... a/c doesnt work .... do you have an idea ...
Re: 2006 honda civic
Are you saying it's not blowing cold air, the compressor isn't engaging at all, the ac button doesn't illuminate at all, what is it that you're saying ? Also, what is "reset the control" ?
the compressor or the fan on the engine does not start ... all lights and control ... heat ... all works ... it seems to loose its memory ... after a certain time ... replaced the control and was ok for a few days ... started up again ... reset the control and ok ... now sometimes the ac wont start ... cycle the switch on and of 2-3 times and the engine fans start and ac is running .... i am wondering if the voltage drops maybe just enough to make the memory loss but not enough to cause any other problems ... any ideas ???
