Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Synchro decisions. 4th gear grinding.
Old 12-30-2016, 04:54 PM
lolv8s's Avatar
Default Synchro decisions. 4th gear grinding.
2006 Civic Si Coupe. Exedy clutch and Exedy lightweight flywheel. 4th gear scratches when I place it into gear now because I tried speed shifting with no clutch.... I know. Big mistake. Either way I assume that's the synchro? Which kit should I buy. I only want what I need. It's just kinda expensive. Just for the Kit. I'm pulling the trans out myself and dropping it off... How would the $700 kit benefit me more than the $450? K20 EP3 Carbon Synchro rebuild kit K20 EP3 Bearing Seal KIt
Old 12-30-2016, 05:34 PM
On vacation
testify's Avatar
Default Re: Synchro decisions. 4th gear grinding.
If you aren't going to do the work yourself, talk to the person who is. As long as there are no surprises when you get it open, you really only need dirt cheap synchro and a bunch of money to spend on labor.
Synchrotech is great, I have a built CTR trans from them and it's flawless.
Old 12-31-2016, 10:13 AM
lolv8s's Avatar
I'm doing the work of pulling the transmission and bringing the parts. I talked to a shop and this guy told me I'll be saving a lot of money bringing my own parts and doing all the labor. They would just be putting in the synchros, bearings, seals, and the 1st-6th springs. I'm just trying to see what other people would think about going $450 for the kit. Or $700 for the kit. Just wanna make sure this is going to eliminate the scratch. It just scratches with some tension when you go into fourth. Is this for sure going to be the synchro? Based on what I have to go by? I'm just trying to make sure. That's why I'm being so cautious.
Old 01-01-2017, 11:56 PM
lolv8s's Avatar
bump
d16efsedan
16
11-29-2016 09:35 PM
gabe768
06-07-2010 03:06 PM
stevenDAtegra
Transmission & Drivetrain
02-04-2010 12:43 PM
ap1_driver
Honda S2000
12
06-18-2006 02:14 AM
hooptie157
05-20-2002 07:31 AM
Quick Reply: Synchro decisions. 4th gear grinding.
