radiator core support
Old May 31, 2005 | 12:21 PM
jdmkillabee's Avatar
Default radiator core support
i was just wondering what is the easiest way to remove and replace a radiator core support for a 95 del sol? please let me know, or any refered sites...thanks
Old May 31, 2005 | 02:31 PM
rotten's Avatar
Default Re: radiator core support (jdmkillabee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkillabee &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering what is the easiest way to remove and replace a radiator core support for a 95 del sol? please let me know, or any refered sites...thanks</TD></TR></TABLE>
Very carefully. J/k.
Basically pretty straighforward. If you can, get a spot weld drill bit.
Otherwise, basically get a machinist's punch, and centerpunch each of the spot welds that hold the core support to the frame (about 30 or so). Probably isn't a bad idea to start with a small bit, drill all the way through, then get a bigger bit and only cut through the upper layer(s). Use a screwdriver to wedge inbetween the sheets and it will pop when you've cut far enough, or you can pop it with the screwdriver after you've cut it a bit. I also use a air hammer/chisel, works pretty good. Doesn't take long to remove.
Good luck.
Old May 31, 2005 | 05:22 PM
swanny's Avatar
Default Re: radiator core support (rotten)
Do a search quick under archived, there a few threads that have gone over this.
Old Jun 1, 2005 | 09:50 AM
Default Re: radiator core support (swanny)
okay then...thanks for the help dude! hopefully i dont mess anything up
RainbowHiker
Northwest
Jul 22, 2016 11:18 PM
lingerfelt
Jun 21, 2012 04:25 AM
louevilhatch
Nov 7, 2007 04:29 AM
jdmCivic925
Jul 13, 2004 04:27 PM
