Subwoofer problems
Old Jul 18, 2008 | 06:11 AM
deerman2701's Avatar
Default Subwoofer problems
Just wired up my subs to 2 ohm load and they sound great in the car but when i pop the trunk andlisten outside the car there is a popping noise sometimes also the bass seems to be delayed? How can i fix this is this a box issue? I think they should hit harder also.
Old Jul 18, 2008 | 06:19 AM
imadigitalgod's Avatar
Default Re: Subwoofer problems (deerman2701)
what amp...what subs....
Old Jul 18, 2008 | 07:55 AM
Default Re: Subwoofer problems (imadigitalgod)
ITs a profile ha700m with 2 12" kicker comps in a sealed box.
Old Jul 18, 2008 | 08:02 AM
Dutch_Mofo's Avatar
When do you hear the popping noise? If you play really loud? And the delay, well, the sub does have a bigger distance from you than your compo. But often it's also a problem of bad integration between compo and sub. You could try to invert the phase. What is the low pass frequency?
Old Jul 18, 2008 | 08:25 AM
Default Re: (Dutch_Mofo)
Popping noise starts around 25 volume of 35 and the low pass filter is all the way down.
Old Jul 18, 2008 | 09:39 AM
That amp gets really hot too i mean to the touch juston the top the sides are fine. I have gain half way how can i fix? Thanks.
Old Jul 18, 2008 | 05:15 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 &raquo;</TD></TR><TR><TD CLASS="quote">That amp gets really hot too i mean to the touch juston the top the sides are fine. I have gain half way how can i fix? Thanks.</TD></TR></TABLE> Which Kicker "comps", [Comp VR, Comp VR-D series, Comp D-series, Comp VT, Comp VX or just the Comp] anything but the Comp, [C12] and you are under-powered.
There are a few things that will "overheat" an amp...
1- Too low a load, [impedance/ohms].
2- Driving amp into constant clipping, [distortion].
3- Poor current, [poor power or ground connections, too small a gauge power cable]. 94
Old Jul 20, 2008 | 07:49 PM
Is it bett for my subs and amp if i set the gain lower and jsut use bass boost? As long as i dont clip? My amp
overheats a lot and was wondering if this would help.
Old Jul 21, 2008 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Turning the gain down will help, but gain at 50%, ["half way"] should not be a problem.
It will not solve a low impedance or insufficient current problem. 94
PS, still need to know which comps you have.
Old Jul 21, 2008 | 10:49 PM
Default Re: Subwoofer problems (fcm)
There just the regular c12's Kicker Comp 07C124 i figured out the problem its the damn sun during the day my box and my amp just bakes in the hot sun all day. Cause i was listening to music all night for about 30 min and the amp is very nice so is yea damn sun haha. The popping noise is gone also and phased up right thanks.
Old Jul 21, 2008 | 10:53 PM
How it plays not playing it loud just breaking em in and the pic of how they look from the back what you think? Dont mind the begin of video lol.
squeek99
Audio / Security / Video
Sep 13, 2007 06:13 AM
supracrx
19
Sep 11, 2007 07:31 PM
SNsLude
Apr 5, 2005 12:15 PM
Supta
Nov 18, 2004 10:24 PM
malix
Jun 9, 2004 03:29 AM
