sub + amp install
Old Aug 2, 2008 | 03:11 PM
masijdm's Avatar
Default sub + amp install
do you guys know any website that shows how to install them because i got everything but when i put remote in cable into cd deck it freezes the deck but amp starts working.
Old Aug 2, 2008 | 03:26 PM
masijdm's Avatar
Default Re: sub + amp install (masijdm)
hellllp
Old Aug 2, 2008 | 03:54 PM
02 accord's Avatar
Don't put the remote cable into the cd deck. You're probably shorting something out when you jam it in there.
Old Aug 2, 2008 | 06:47 PM
schmiddr2's Avatar
It does seem that your shorting out the head unit. I assume this is an aftermarket radio. It's wire should be blue which you attach the remote lead to. And on the amp it says rem. But there could be other things wrong. Website for learning, should always do this step first -
http://www.crutchfield.com/App...tp=14
Old Aug 3, 2008 | 06:30 AM
fcm's Avatar
fcm
Old Fart
More info...
MM&Y of car?
Make and model of HU, [cd deck]?
Make and model of amp?
Where exactly are you "put remote in cable into cd deck " into HU?
Where and how is the amp grounded?
What gauge is the amps power and ground cable?
When the HU was installed was a harness adapter used? 94
Old Aug 6, 2008 | 05:28 PM
masijdm's Avatar
Default Re: sub + amp install (fcm)
Acura Integra 1998
Sony CDX-GT510
Kenwood AMP
Alpine type-R Subwoofers 12"
The Remote in Cable is only thing that freezes my CD Deck:{ the small blue wire from amp into deck.
Old Aug 7, 2008 | 11:34 AM
fcm's Avatar
fcm
Old Fart
Well that helps, now how about the rest of the questions?
"Where exactly are you "put remote in cable into cd deck " into HU?
Specifically, what lead on the HU are you connecting the amps control lead to?
Try this, with HU on touch the amps remote lead to the amps power cable terminal, amp should turn on. 94
Old Aug 7, 2008 | 02:20 PM
masijdm's Avatar
i got it i had to just hook the blue with blue wire inside CD deck wire harness because ikept putting it in wrong spot thanks thought
Maleek
Audio / Security / Video
Jul 23, 2009 05:19 AM
autoEk
Aug 7, 2006 03:41 PM
92-LS-Civic
May 1, 2006 11:19 PM
noah88
Oct 22, 2004 08:10 AM
zcivicz
Mar 24, 2003 05:04 PM
