does this amp make a good pair with this sub?
Old Jul 22, 2008 | 10:22 AM
zsudz922's Avatar
Default does this amp make a good pair with this sub?
i was wondering what amp would pair up good with a Alpine SWR-1542D type r 15'' sub. i want to get an Alpine amp but they dont have one that matches good to the sub. i was thinking the Alpine MRP-M1000 @ 1000 watts RMS@2 ohms, but that may be a bit too much power for the sub. maybe a Kenwood KAC-9104D @ 900 watts RMS@ 2 ohms? or a JBL GTO7001 @ 700 watts RMS@ 2 ohms? any other suggestions to a good amp for this sub? i will have a Rockford Fosgate 2F capacitor for the system as well.
i am also worried that it may not fit in my trunk. i have 16 1/2''-17'' to work with in height,im good in width and depth. will it fit in a custom box? the cutout diameter only needs to be about 14''(13 13/16'') for the 15'' type r sub. what do you guys think?
much appreciate any help. thanks
links for everything:
sub http://www.crutchfield.com/App...specs
Alpine amp http://www.crutchfield.com/App...specs
Kenwood amp http://www.crutchfield.com/App...specs
JBL amp http://www.onlinecarstereo.com...19889
Old Jul 22, 2008 | 11:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: does this amp make a good pair with this sub? (zsudz922)
The Alpine amp MRP-M1000 will be fine, "it's better to be over-powered then under-powered" just do not turn the amps gain all the way up. 94
Old Jul 22, 2008 | 11:56 AM
zsudz922's Avatar
Default Re: does this amp make a good pair with this sub? (fcm)
sweet, thanks. do you think a 4G wire from the battery to the cap/amp will be enough?
i hope the sub will fit in my trunk without too much hassle.
Old Jul 22, 2008 | 08:50 PM
mattison187's Avatar
fo with atleast 2 guage. IMO you should do 1/0. 1000w rms is alot of draw on an electrical system. you should do your big3 also if you havent allready.
Old Jul 22, 2008 | 10:03 PM
schmiddr2's Avatar
Actually a 4 Ga. is recommended. The price difference is not much from 4 to 0/1 so go that way. Allows room for improvements. The box will fit with little trouble. Specs to know:
# Displacement: 0.123 cu. ft. (Front Mount)
# • Mounting Diameter: 349 mm (13.8'')
# • Mounting Depth: 234 mm (9.2'')
And you are looking at 1.75 cu ft total. So go here and figure out the dimensions needed http://www.the12volt.com/caraudio/boxcalcs.asp
More specs: http://support.alpine-usa.com/...D.PDF
Old Jul 22, 2008 | 10:53 PM
Default Re: does this amp make a good pair with this sub? (schmiddr2)
4 gauge is min. not recommended lol. id go 2 ga. for power/ground. and 4 ga for big3 minimum. remember the less resistence= the less voltage drops. oh and id loose the cap. look into a batcap or mabey a kinetic hc600. just my $.02
Old Jul 22, 2008 | 11:12 PM
schmiddr2's Avatar
Default Re: does this amp make a good pair with this sub? (mattison187)
Yes it is. lol. Have you read the Alpine manual? No. And the capacitor should work just fine, and further power upgrades are always ok.
Old Jul 23, 2008 | 04:40 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zsudz922 &raquo;</TD></TR><TR><TD CLASS="quote">sweet, thanks. do you think a 4G wire from the battery to the cap/amp will be enough?
i hope the sub will fit in my trunk without too much hassle.</TD></TR></TABLE> You can use 4ga if the cable is up to 8'-10' long, any longer then that and I would recommend 2ga and 2ga wouldn't hurt even if it is shorter then 10'.
You should definitely "beef up" the batt. to chassis and chassis to motor grounds, at the very least the batt. to chassis ground, I see no point in upgrading the alt. to batt. charge line unless you are upgrading the alt., although it can't hurt anything.
The box should be no problem, recommended "optimum" sealed box is only 1.025cuft net, add the subs displacement, [front mount] of .123cuft and you have 1.148cuft gross, that's a pretty small box for a 15" sub, even the vented box is only 2.25cuft net. 94
Old Jul 23, 2008 | 09:05 AM
zsudz922's Avatar
yeah, i was just worried about the height of the sub/box since i only have 16.5''-17'' to work with in height. that link to figure out the box dimensions is sweet.
what amp fuse should i use? 100,150, or 200 amp?
thanks for the help guys.
Modified by zsudz922 at 1:22 PM 7/23/2008
Old Jul 23, 2008 | 02:25 PM
AzntaggeR's Avatar
TSPeed Factory
if you got the cashe i'd go with the alpine pdx1.1000
Old Jul 23, 2008 | 04:16 PM
It Wasn't Me's Avatar
Default Re: does this amp make a good pair with this sub? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">if you got the cash I'd go with the Alpine PDX1000.1 </TD></TR></TABLE>
x2
The PDX provides much cleaner, more accurate power than the MRP models. It's well worth the extra funds. Personally, I favor JL Audio over any other brand.
Old Jul 23, 2008 | 04:47 PM
fcm's Avatar
fcm
Old Fart
If it's 4ga us a 150A ANL fuse, if it's 2ga use a 225A ANL fuse. 94
Old Jul 23, 2008 | 06:36 PM
zsudz922's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">if you got the cashe i'd go with the alpine pdx1.1000 </TD></TR></TABLE>
that was my thoughts too. but i dont have the extra money right now. ill possibly upgrade to that later down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If it's 4ga us a 150A ANL fuse, if it's 2ga use a 225A ANL fuse. 94</TD></TR></TABLE>
actually i ended up getting 1/0ga. it comes with a 150 amp ANL fuse. i guess i should buy a bigger one?
thanks.
Old Jul 24, 2008 | 04:52 PM
fcm's Avatar
fcm
Old Fart
A 1/0ga has a 350A capacity. 94
Old Jul 24, 2008 | 06:59 PM
zsudz922's Avatar
i bought a 250amp fuse to put in. do you think that will work fine? im just running this one mono amp on it, i have a separate 4ga for my 4-chan amp.
Old Jul 25, 2008 | 04:44 AM
fcm's Avatar
fcm
Old Fart
Yes, although the cable will handle more the fuse does not need to be any bigger then what the amp has in it. 94
Old Jul 25, 2008 | 06:40 AM
zsudz922's Avatar
ok, thanks for your help. i appreciate it.
dseriesboulder
Audio / Security / Video
11
Mar 14, 2013 07:01 PM
ChiLS
Feb 21, 2009 10:16 AM
JDMcivicSiEG6
Mar 12, 2008 09:02 PM
albertlnguyen
Nov 5, 2007 05:39 PM
VietFoo
Dec 25, 2005 12:03 AM
