IPOD ?
Old Jul 31, 2008 | 03:16 PM
Civic92Turbo's Avatar
Default IPOD ?
so i been driving my car without a deck for some time due to the fact it blew out. but from what i have seen, not to long ago some one hooked up there ipod to there system Amp and Subs and i cant seem to find that Post can some one update me on this? i rather save the money since i already have subs and a amp. and instead of buying a new deck
Old Jul 31, 2008 | 07:31 PM
02 accord's Avatar
Default Re: IPOD ? (Civic92Turbo)
Get a headphone to rca adapter, and plug that into the iPod and amp respectively. Then connect the remote wire from the amp to a power source through a switch (accessory off the key would work), and you're done.
Old Aug 4, 2008 | 07:52 PM
rattmann316's Avatar
Default Re: IPOD ? (02 accord)
i wonder if the output voltage is high enough for an enjoyable experience? i mean, what is the output voltage-wise of a 3.5mm jack?
Old Aug 5, 2008 | 05:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: IPOD ? (rattmann316)
If it is high enough to drive a set of headphones it is high enough to drive a car amp.
As for being an "enjoyable experience" that depends on the listener, SQ will not be very good as it would be amplifying an amplified signal, but if connecting directly to the amp it is the only way to do it to have any kind of control, [besides volume], for better SQ you would need to use the preamp output of the docking port, [docking port to RCA adapter], and yes there is enough "voltage" from the preamp output to drive an amp, although a preamp control of some sort is needed, [like a HU with AUX input, or ideally a HU with iPod control]. 94
ChiLS
Audio / Security / Video
Feb 21, 2009 10:16 AM
FULL throTTLe
10
Jul 20, 2007 12:24 PM
NonovUrbizniz
24
Mar 17, 2006 08:20 PM
Jonathan_ED3
11
Jul 9, 2003 10:33 AM
woodog
Dec 17, 2001 11:08 PM
