Radio not working
Old Jul 29, 2008 | 10:46 AM
fortymcpants's Avatar
Default Radio not working
Pretty simple, the radio I had in my carwould cut out every once in a while so I decided after 5 years the alpine should be replaced. I put in the new radio and got nothing, no power. I hard wired it to the battery and it worked so I know its not the radio. I even plugged in the old alpine and still got nothing where as it used to work for about 5 minutes or so and then cut off. I checked the fuse and its not blown. Also I pulled all the under dash wiring and dont see anything bad with it. Any suggestions are welcome, I gotta find a multimeter to check the wiring for sure but like I said it looks fine all the way back to the fuse box.
Old Jul 29, 2008 | 03:57 PM
CRJenkins13's Avatar
Default Re: Radio not working (fortymcpants)
Have you hooked up your constant? Are you sure your connections are all good? What harness did you use? Did you buy a smart harness from Circuit City or did you actually hardwire it yourself?
Old Jul 29, 2008 | 05:40 PM
Default Re: Radio not working (CRJenkins13)
The constant was hooked up
The connections are good, even the grounds
I used a smart harness from Circuit City, then I took it apart because the pins were falling out and hard wired it
Old Jul 31, 2008 | 04:27 PM
bump
Old Jul 31, 2008 | 05:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: (fortymcpants)
Are you using stock speakers or aftermarket speakers?
There are two fuses you need to check, the radio acc. fuse in the under dash fuse box and the constant power fuse, in the engine bay fuse box, [probably a 7.5A]. 94
Old Aug 2, 2008 | 01:10 PM
Thanks i'll ckeck it as soon as I get home!
kikla
Audio / Security / Video
Jan 12, 2012 04:55 PM
mannydhanju
Jan 18, 2009 06:45 PM
scorpio1472000
Nov 27, 2007 07:15 PM
Leo C
Jan 13, 2007 02:18 PM
crawdad689
Dec 10, 2003 01:38 PM
