Rca cable
Old Jul 9, 2008 | 04:23 PM
deerman2701's Avatar
Default Rca cable
Ok so i was just looking at my rca cable hooked to my amp and i noticed a problem. one of the jacks broke off in the amp the little prong thing. Now do i have to replace the whole rca cable of what other options do i have?
Old Jul 9, 2008 | 04:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: Rca cable (deerman2701)
You could just buy an RCA end and replace the broken one, it will require some soldering, I do not recommend that option for anyone that has not terminated RCA ends before.
Although it may not look like it, it will probably be easier for you to just replace the RCA cable with a new one. 94
Old Jul 9, 2008 | 04:54 PM
Default Re: Rca cable (fcm)
Ok fcm what about getting the end out of the amp ive been trying but cant get it out.
Old Jul 9, 2008 | 05:30 PM
schmiddr2's Avatar
Find a screw that just fits into it. Screw it in a bit then pull. Use some hemostats. Take it to a car audio shop and they will probably pull it for free. Use your imagination and technical know how.
Old Jul 10, 2008 | 05:31 AM
fcm's Avatar
fcm
Old Fart
Easiest way is to "open" the amp up, remove cover and push it out from the inside, you may also be able to pull it out using a "pick", I have pulled a few using my right angle pick... http://buy1.snapon.com/catalog...talog you may have something that will work.
The important thing is not to damage the amps RCA plug. 94
Old Jul 10, 2008 | 11:50 AM
schmiddr2's Avatar
Agreed, don't scrape up the rca's in the process, I thought that would be obvious though. If you amp is still under warranty opening it can void that warranty.
Yun_Ej2
Audio / Security / Video
12
Sep 11, 2010 06:13 PM
deeweezy
Apr 5, 2004 06:38 PM
fronell
Dec 30, 2002 07:30 PM
ajshades
Sep 6, 2002 07:37 PM
