Integra Component Speaker Install
Old Aug 6, 2008 | 12:26 PM
TonyRomo's Avatar
Default Integra Component Speaker Install
So there are the blue and gray oem wires. I was wondering which color plugs into which prong in the aftermarket speakers. The speakers have a big and small one, the big one has a black wire going to it and the small is clear(can see the actual wire).
Thanks
Old Aug 6, 2008 | 05:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: Integra Component Speaker Install (TonyRomo)
The "bigger" terminal is the pos.(+) and the "smaller" terminal is the neg.(-) although it makes no diff. which way you plug them in, as long as the left and right speakers are plugged in the same way, [if not the speakers will be out of phase].
To test, install the speakers, turn on your favorite tunes, not too loud, then using the HUs balance control, balance all the way to the left or right speaker, if the bass response is better when only one speaker is on then when both speakers are on, you have wired them out of phase, switch the wiring on one of the speakers, it makes no diff. which speaker you switch the wires on, it will put the speakers in phase.
BTW gray and brown are normally speaker neg.(-) on Honda/Acura... http://www.installdr.com/Harnesses/HA-Wiring.pdf 94
Old Aug 7, 2008 | 12:14 AM
TonyRomo's Avatar
Default Re: Integra Component Speaker Install (fcm)
got it thanks
fromstangtocrx
Audio / Security / Video
Oct 17, 2006 12:51 PM
aoshiblade
10
Jul 26, 2005 11:18 AM
rentacop
Aug 28, 2004 05:27 PM
lotas
Aug 20, 2004 10:21 AM
[Ne0]
Dec 2, 2001 03:26 PM
