DECK INSTALLATION HELP!
Old Aug 2, 2008 | 03:50 PM
eg831's Avatar
Default DECK INSTALLATION HELP!
I have a pioneer deck that i'm trying to splice to my stock 88 civic sedan harness and i am getting NO power to my deck. It is connected right, but still no power. What could be wrong?!? Please help me out
****I just found out that i'm not getting any power to the harness for the radio, but again, all the fuses are good. Please help
Modified by eg831 at 5:10 PM 8/2/2008
Old Aug 2, 2008 | 03:55 PM
02 accord's Avatar
Default Re: DECK INSTALLATION HELP! (eg831)
Blown fuse? Nahh, that would be too obvious.
Old Aug 2, 2008 | 03:56 PM
eg831's Avatar
Default Re: DECK INSTALLATION HELP! (02 accord)
checked all the fuses and there all good
Old Aug 2, 2008 | 06:53 PM
schmiddr2's Avatar
The wire could be broken, fallen off it's terminal, or have been cut. The easiest thing to do it run a new wire from battery to deck. If you have a meter it's pretty simple to fix. Look here to make sure you have it wired correctly -
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Old Aug 2, 2008 | 09:10 PM
fcm's Avatar
fcm
Old Fart
Does an "88 Civic sedan" have an engine bay fuse box?
If so, did you check the fuses in there?
You should have two power leads at the radio harness, a constant power and an acc. power, the constant power fuse is normally in the engine bay fuse box, almost always a 7.5A.
You should rewire the HUs constant power directly to the batt. 94
Kyle700
Audio / Security / Video
Oct 17, 2014 09:08 PM
idumpwitmy12gaugepump
May 22, 2008 07:18 PM
Leo C
Jan 13, 2007 02:18 PM
mxl36o
Nov 26, 2006 04:48 PM
turbotime
May 29, 2005 08:27 PM
