car alarm problems
Old Jul 16, 2008 | 05:53 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default car alarm problems
well i installed my new 2 way paging dei alarm and i got the alarm itself to work, got all the inputs wired up, but im having a hard time getting the fuel kill to work, i used the write up and used a 4 pin relay, using the orange wire off the main 7 pin harness and it wont give it power when i turn the key to the on position? what am i doing wrong here?
Old Jul 16, 2008 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Default Re: car alarm problems (EARLdaSQUIRREL)
Hard to say what you did wrong with discription supplied.
By "4 pin relay' do you mean a SPST relay, if so it is the wrong relay if you are using the ground out when armed lead, [orange] from the alarm.
A SPST relay is N/O, [normally open] and closes when energized, alarm armed.
What lead have you installed the relay on? 94
Old Jul 16, 2008 | 11:12 AM
Default Re: car alarm problems (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Hard to say what you did wrong with discription supplied.
thats probably the problem then, its a 4 pin relay (only relay radio shack had in stock) i guess i will order a new relay and see if that works
weekendboost
Audio / Security / Video
Feb 18, 2013 10:18 AM
YellowPhoenix095
Feb 3, 2008 07:10 AM
hondachris1994
Feb 2, 2007 09:40 AM
snapcase318
Oct 15, 2003 10:17 AM
ultimatehonda
Jan 21, 2003 02:43 AM
